idle problem
Old Oct 9, 2002 | 01:10 PM
chirp2hrd's Avatar
Default idle problem
i just got new wires for my b16 and sometimes the car wants to turn off like it has no idle when i brake or stop i have to keep my foot on the gass it acrts liek it has no idle it only act fine sometimes any ideas the car drops to 0 rpm and turns off most of the tims enless i keep my foot on the gas
Old Oct 9, 2002 | 02:13 PM
lazy bum shaughn's Avatar
Default Re: idle problem (chirp2hrd)
Check the idle valve thing, or for loose hoese.
Old Oct 10, 2002 | 06:01 PM
sporkcrx's Avatar
Default Re: idle problem (Breakdancer)
hey man, the EXACT same thing has been happening to me....have you solved it yet? -sean
Old Oct 10, 2002 | 06:53 PM
MrTodd's Avatar
Default Re: idle problem (spoon2)
Unscrew the idle adjusting screw located on the TB a bit to increase the idle speed.
Old Oct 10, 2002 | 07:56 PM
sporkcrx's Avatar
Default Re: idle problem (MrTodd)
well my idle is fine....when it's been driving for a couple mins. but when i start hot it'll just die unless i keep my foot on teh gas, and when it's started cold, after a minute or two, when i blip the throttle to drop the revs it'll die...or come really close to dying, then slowly go up to a high cold idle.
Old Oct 11, 2002 | 11:56 AM
chirp2hrd's Avatar
spoon2 that is my EXACT problem i think it is my throttle cable holder and my idle adjustment screw moves by its self it worked good for a lil when i adjusted it but i hate it when it wants to die
Old Oct 11, 2002 | 12:24 PM
altoid's Avatar
fast idle valve, idle nut or vacuum leak can do that
Old Oct 12, 2002 | 08:35 PM
sporkcrx's Avatar
Default Re: idle problem (altoid)
is there a way to test the fast idle valve? and chirp2hrd...keep me updated if you fix it!
Old Oct 12, 2002 | 08:37 PM
sporkcrx's Avatar
I got the problem after installing a new cam...but after a day or two I put on new wires too, odd.
Old Oct 13, 2002 | 01:36 AM
ULTRA911's Avatar
try putting back your old wires and see if it wants to die out. if it doesn't die out, something is wrong with the new wires. if it does, some sort of vacuum leak, or idle screw needs adjusting (make sure u unplug the iacv sensor first), or check the throttle cable if it's tight enough.
99d-series
May 18, 2009 04:51 PM
jdm4drSi
Apr 6, 2007 08:19 AM
SilverSellout
12
Feb 27, 2004 12:48 PM
killa_lude
Aug 16, 2003 08:33 AM
350z-tech
Nov 10, 2001 10:46 PM
