Piston/Rod combo - advice/opinions
I finally got my tax return and it's time to buy the pistons and rods for my LSVtec Turbo setup (see link in signature). I'm going for 400-500whp with lower boost.
Let me know what you guys think of this deal, and are these rods going to be okay
http://www.ebay.com/itm/Wiseco-Forge...item5ae13802ec
I haven't checked, I will have to look into that. 785$ seems like it's a fairly good price for pistons and rods, but I'll look into the sponsors now. Thanks, any other input?
Eagle and Wiseco are what the majority go with, and is what i'll be using when i swap. i say push yes but i believe their are sponors on here that sell them cheaper like stated above.
Here's the same company just on here for cheaper
https://honda-tech.com/forums/showth...ston+rod+combo
Wiseco, JE, and some companies use different alloys from SRP. It's stronger but has a higher coefficient of expansion. It's fine, especially considering it's only an 81mm piston, but SRP (cheaper line of JE) use the same alloy as cast OEM pistons so they expand less, meaning a tighter p2w clearance, and should last a little longer. Not sure if they're good for that much power though.
From: Pensacola, FL and every Court House in Louisiana
I always heard CP pistons were good and one of the only pistons which clearances are always within a thousandth of an inch, I want to say.
What are FR rods? Have you done ANY research? Did you check any of the links that have been posted? Define "cheaper". What is your budget?
