Yup its the Head Gasket
ok so me and a friend are doing my head gasket tomorrow on my 2000 honda civic lx d16y7 sohc non vtec i got a few questions i like to ask first is the torque specs for the head bolts and the tightening sequence for them and secondly i am gonna do timing belt and water pump so i was wondering sinse i dont have a air gun how can i break the crank pulley bolt? i got a bigass breaker bar but im not sure if that will do it. any other things i need to know shoot them at me thanks guys
Don't start taking the car apart, until you can loosen the bolt. You may need to drive it to a shop, and have them do it.
You'll want the crank pulley tool, and big *** breaker bar, and cheater pipe.
They don't like coming off.
next time google "d series torque specs" brah
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/%5Bfaq%5D-d-series-torque-specs-everyone-1169414/
Then don't! Go rent the tool for free.
Got my $50.00 bucks back, after I returned it as well. Its free. Orielys rents out the tools. It was simple to remove after that. Torque specs are just as imporant as the torqing order. Hanes manual/ google will be extremely beneficial. Pick up coolant, and be pre-pair to do an oil flush/ replace filter. Go through the threads with a tap to ensure they're cleaned out. You'd be suprised how much **** will be in there. I suggest replacing your timing belt at the same time. Why go through the hours of time at two different times when you can complete it all at once? Gl.
i got mine from this site for $50 and it came with valve gauge feelers, valve adjustment tool, and the crank pulley tool. too bad they are out of stock
http://www.denlorstools.com/home/dt1...0mm_valve.html
Off topic: this method DOES NOT work on these motors because the motor will spin the same direction as the bolt. If you wedge a breaker bar in there on that bolt and crank the motor, you'll only tighten the bolt even more (or likely destroy the breaker bar and send pieces of metal flying everywhere).
Just my 2 cents.
Just my 2 cents.
. M i c h a e l
Oct 19, 2005 05:39 PM
