86x92 beries dyno toda c
Old Jan 30, 2012 | 07:37 AM
Chugger's Avatar
Default 86x92 beries dyno toda c
i got my car dynoed this weekend happy with the results so far
mod list
86mm bored itr block
92mm crower crank
carrillo ultra light rods
wiseco offset 12.25 pistons
itr head with valvejob
revhard im (victorx copy)
smsp header
3" exhaust
68mm skunk2 billet tb
toda c cams
custom 4" intake and 6" vstack
93 octane
car:
chart:
See anything wrong?
Old Jan 30, 2012 | 07:59 AM
koczeka's Avatar
Default Re: 86x92 beries dyno toda c
Nice flat powerband.
Get bigger cams and rev it 500 more!
Old Jan 30, 2012 | 08:09 AM
Chugger's Avatar
well the chart is the low cam, we tried and tried vtec would not engage but I dont believe those numbers arent bad for the toda c primaries
Old Jan 30, 2012 | 08:13 AM
SR20S13's Avatar
jeez 200whp out of that without vtec is pretty nice, you would pick up alot of power if you could get vtec to work haha, BUT what did you try to get it to work?
Old Jan 30, 2012 | 08:17 AM
Chugger's Avatar
everything minus pulling the rocker arms out and checking them.
The motor has been assembled for about 4 yrs cant remember if I assembled the head or the machine shop after the valve job but I am taking bets that something is missing in the rocker arm assembly. I have never messed up installing rocker arms but who knows gonna tear the top end apart one evening this week and see whats up
Old Jan 30, 2012 | 08:21 AM
slowsleeper's Avatar
I was going to say, that those were low whp/trq numbers for that size until I read the no VTEC part. Nice numbers on the low cam for sure.
Old Jan 30, 2012 | 08:54 AM
cibao2ner's Avatar
wow you made more power without vtec than most builds on this site make on lsvtecs..
check the 0 ring on cam cap number 3..and bypass the oil pressure switch if you havent done it...most comon reasons for vtec not working..
Old Jan 30, 2012 | 08:58 AM
blackeg's Avatar
Yea I was also going to say check that o ring #3 camcap
Old Jan 30, 2012 | 09:07 AM
Fink29's Avatar
Great torque numbers for no vtec!
Make me want to put my car back together and go get some number!
85x92 here!
Old Jan 30, 2012 | 11:16 AM
chickenbandit's Avatar
x2 happend to me once
easy fix
Old Jan 30, 2012 | 11:43 AM
Chugger's Avatar
Just checked the o-ring is there but the dowel pin isnt in the #3 cap?
Everything else looks good all the rockers are correct
Old Jan 30, 2012 | 12:04 PM
Fink29's Avatar
Easy Fix! Glad you figured it out quick
Old Jan 30, 2012 | 12:14 PM
blackeg's Avatar
yeah pretty quick fix. get that dowel pin in!
Old Jan 30, 2012 | 01:24 PM
Chugger's Avatar
Not sure if thats gonna fix it but thats all i see thats not correct
Old Jan 30, 2012 | 01:54 PM
DDTECH's Avatar
Car will make 250+whp with vtec.. Nice numbers.
Smooth that AFR out, that car's setup should like 13.3-13.1 AFR
Did you jump the vtec noid?? Do you hear it click?
Old Jan 30, 2012 | 02:22 PM
Chugger's Avatar
Yep jumped the soleniod even tried jumping it during a pull but no luck
It did click
Old Jan 30, 2012 | 02:48 PM
DDTECH's Avatar
Something inside isn't working properly, at least you've narrowed that down.. check the rockets, make sure everything locks up.
Old Jan 30, 2012 | 03:09 PM
b20vtek's Avatar
looks like an easy 250whp, remind me of mines when I tuned the first time it made 210whp with no vtech @7k. good luck finding the problem.
Old Jan 30, 2012 | 03:16 PM
snm95ls's Avatar
I'd like to see updated power numbers and a dyno plot when you get it fixed.
That things looks pretty damn healthy.
Old Jan 30, 2012 | 06:04 PM
Casey's Avatar
glad you at least got going on this thing chris. cant wait to see it with vtak.
Old Jan 30, 2012 | 06:13 PM
GSRswapandslow v2's Avatar
good to see my old motor going again...
just think...6 years ago the thing made 191/126 with i/h/e....before going to RLZ for the build....and you just beat those number...ON THE LOW CAM!!
Old Jan 31, 2012 | 02:53 AM
Chugger's Avatar
I installed the dowel pin with a new oring but it just seems too simple for that to fix it?
Does anyone have a nice pic of a dissambled rockerarm I can look at to make sure everything is correct I mean everything looks right but doenst mean it is. Curious which rocker locks first, second and last just curious about the orientation.
thanks everyone for your help.
Old Jan 31, 2012 | 02:54 AM
Chugger's Avatar
Thanks casey yes it has been a very long time coming it sounded great but no vtak.
Old Jan 31, 2012 | 02:56 AM
Chugger's Avatar
I cant wait to get it up and running correctly gonna drive it for awhile and getahead and send it to 4 piston and get a set of roller cams and rockers along with a set of kinslers.
My goal is to make 300whp on pump 93 or e85 if more then great haha
Old Jan 31, 2012 | 06:34 AM
importfan2's Avatar
cant wait to get my toda c's on the dyno
motor looks like it healthy
