need a confirmed guide for d16z6 swap
Old Jan 29, 2012 | 08:32 PM
mack0603's Avatar
Default need a confirmed guide for d16z6 swap
Bought a 89 ef hatch ment condition for 300 bucks from some old man who was the original owner of it. has a 121k miles on it will crank but wont spark.
recently bought a d16z6,the tranny and the ecu and harness from the salvage yard that some airforce guy brought in. he brought the car from germany is was a del sol body but said CRX exsi..... was confused when i seen this. the motor runs and drives great but he cant take it back with him and sold it to the junkyard.
i got the motor,tranny,harness,and ecu for 400$.
My current motor is DPFI and the Z6 of course is MPFI, i just need a guide to dropping the z6 in and doing the wiring right found a few but just need a confirmation on which one the pros here think i should use in orer to do the swap correctly.
Old Jan 30, 2012 | 07:07 AM
BiGZ's Avatar
Default Re: need a confirmed guide for d16z6 swap
Look in the FAQ,all covered! (search mpfi swap,OBD1 conversion if wanting to run the del sol's ecu)
Old Jan 30, 2012 | 07:31 AM
4drEF's Avatar
Keyboard Humorist
Is your car automatic?
What transmission are you planning to use?
Google has tons of info.
Here's a start if you plan to do the basic swap with "normal" parts.
http://www.d-series.org/forums/diy-f...-y8-z6-ef.html
Old Jan 30, 2012 | 07:33 AM
Bumpysbro's Avatar
just google it, this has been covered so many times.
Old Jan 30, 2012 | 12:55 PM
mack0603's Avatar
Currently in the car-d15b8,4sp manual tranny, stock ecu, evernything stock atm for the 89 ef hatch.
currently in the garage, d16z6 all components with it,d16z6 tranny,p28 ecu that came withit,wiring harness from delsol.
just need to know what more do i really need from what i understand its a straight drop with a little mod to the timing belt cover.and redoing the wiring from the harness to the bay and ecu. i found a few link but seem to be all about the ZC and not so confident on which write up to use. i want this to go as smoothly as possible and trying to get all the parts i need before i get into it,
Old Jan 30, 2012 | 12:56 PM
mack0603's Avatar
sorry for poor typos but busy at work while trying to get this info.
Old Jan 30, 2012 | 03:42 PM
KINGVEM^^ED6's Avatar
Id go back and snag parts off that sol
Old Jan 30, 2012 | 08:51 PM
mack0603's Avatar
what other parts should i get from it??
Old Jan 31, 2012 | 07:54 AM
94EG8's Avatar
Seagull Management
Sell the hydro tranny and pick up a cable Si tranny (avoid the '88 tranny if you can) You can either convert the car to OBD1 or run a chipped OBD0 PR3 along with an OBD0 distributor with 1 leg cut off, and OBD0 injectors from a D16A or a B18A1.
Old Jan 31, 2012 | 11:07 AM
mack0603's Avatar
Going to convert it and use the p28 i have with the motor, trying to figure out hard the hydro tranny would eb to convert cause dont know where to get the ef si tranny at dont kow they trany code number or anything maybe a little advise on what to look for here at the salvage yard as far as part numbers?
tgraeter7
Sep 11, 2011 04:16 PM
zeroairskter
Dec 28, 2010 10:57 AM
RedRevolver
15
Dec 10, 2008 06:15 PM
EFstyle
Jul 1, 2006 11:33 AM
Mario.
Aug 23, 2005 09:24 AM
