97 prelude without balancer pulley
Old Jan 20, 2012 | 09:06 PM
Wingman00SI's Avatar
Icon2 97 prelude without balancer pulley
Got a question? Does anybody know whats the deal when a h22A4 not having the front timing belt balancer pulley? It has the rear timing belt balancer pulley but that's it and all the pics i have seen have both!
Old Jan 21, 2012 | 05:13 AM
97ludedude's Avatar
Default Re: 97 prelude without balancer pulley
i am not fulling understanding what you are asking. Are you trying to ask why someone has removed your balance shaft pulleys? Are you talking about the one on the crankshaft or by the timing belt tensioner? Post a picture or elaborate some.
Old Jan 21, 2012 | 07:00 AM
Apex1972's Avatar
needs moar info. but i an guessing that someone has removed the balance shaft belt. all in the search for 3 more whp, lol.
Old Jan 21, 2012 | 08:38 AM
snobordboy's Avatar
Moderator
If the pulley is gone, there should be some type of spacer in there, or the timing belt will walk out, and rub on the valve cover and timing covers, and destroy itself.
My other thought, are you looking at the outer crank pulley, and it has a single row pulley on there, and no power steering?
Old Jan 21, 2012 | 09:04 AM
Sorry guys here is a pic.
I,m new at this so hopefully this works. this is exactly what it looks like. It has what I circled in blue and I am missing what I circled in red. When i took off the plastic side covers this is the way it was, so it came like this from Honda or the previous owner wanted a whopping 3hp. Thanks for your help guys. Oh ya this is not my block, this is the only pic i found on google that looked exactly the same.
Old Jan 21, 2012 | 09:06 AM
Old Jan 21, 2012 | 09:12 AM
everything i have seen looks like this with both balancer shafts.
Old Jan 21, 2012 | 12:02 PM
97ludedude's Avatar
Someone has done a balance shaft delete on your motor. It is not going to hurt anything. Actually it should give you more oil pressure and you also have less rotating mass and removes a couple of pounds. I would consider it a good thing.
Old Jan 21, 2012 | 12:04 PM
Cool thanks alot!!!
crvglenn
Honda CR-V & Element
Aug 20, 2017 01:44 AM
us31wking
Aug 21, 2014 04:50 AM
hmtcrxsir
Dec 22, 2009 10:21 AM
DocSean
Jan 16, 2006 09:20 PM
sbigblack02
Apr 3, 2004 07:21 AM
