b20 in ek problem help!
Old Jan 15, 2012 | 03:42 PM
MMMGIRL's Avatar
Default b20 in ek problem help!
Earlier today i put a b20b in my ek and wired everything up. Well i went to start it and it runs really rough, its like its misfing, ias far as im aware all the sensor plugs are in the right place, any and all help is appreciated, thanks
Old Jan 15, 2012 | 04:32 PM
Former User's Avatar
Default Re: b20 in ek problem help!
CEL codes? Plug wires in correct firing order?
Old Jan 15, 2012 | 04:38 PM
MMMGIRL's Avatar
Wires are right and only cel is o2 sensor
Old Jan 15, 2012 | 04:40 PM
Are you using the correct ECU?
How old are the plugs, wires, cap, and rotor?
Have you checked the mechanical timing and cylinder compressions?
Old Jan 15, 2012 | 04:45 PM
MMMGIRL's Avatar
Timings good i drove the teg i took it out of yesterday into my garage, im not sire how old tey are tbh i took them off a ls engine
Old Jan 15, 2012 | 04:57 PM
canadaek's Avatar
so did you take out the b18b you just put in and couldn't get running ?
Old Jan 15, 2012 | 05:05 PM
MMMGIRL's Avatar
Nope it had a rod knock but it did the same thing as the b20. I took the im and dizzy off the ls and put it on the b20
Old Jan 15, 2012 | 05:07 PM
Bad distributor? --> inspect and test it.
Old Jan 15, 2012 | 05:09 PM
grumblemarc's Avatar
The Grumpiest
Still didn't say what ECU.
Old Jan 15, 2012 | 05:10 PM
MMMGIRL's Avatar
Iused the dizzy and wires off the ls and its a p75
Old Jan 15, 2012 | 05:45 PM
canadaek's Avatar
well if they both did the same thing it's wiring or dizzy
Old Jan 16, 2012 | 06:03 AM
kyden's Avatar
do you have the map and tps plugs in the right place? they're the exact same plugs and people connect them wrong all the time.
smurf357
Oct 7, 2009 06:24 PM
mach0
11
Jan 27, 2009 08:39 AM
WhiteEkCivic
Oct 24, 2007 02:17 PM
bluntman427
Mar 6, 2007 08:11 PM
96LsBang
Aug 15, 2006 07:55 AM
