max hp f22b sleeves can handle
hey guys have a g22 swap.the f22b2 block is stock but i plan on ordering pistons and rods.question is how much power/boost can stock sleeves handle.anyone recommend putting new sleeves?looking hp wise anywhere between 4 to 500whp.thanxs guys.
I agree with the 300whp. Anything over that and you are going to want to stabilize the cylinders. Looking for 4-500whp you are definitely going to want to close up the open deck or pin the cylinders.
The H22 and F22 are the same block guard. If these are installed properly there are no issues. The H22a1 is a closed deck with less flow rating as most block guards have. The key is how far down the block guard is installed in the block.
The block guard should be pressed 1/4" - 5/8" into down past the deck surface. It should obviously be aluminum and it should be tig welded into place. Tacks will do! Then the cylinders and main journals should be honed/aline honed.
I have a good quality H23/H22/F22 block guard if anyone is looking.
I do not agree but understand the logic for why people brace cyl's. Open deck Honda motors with unpinned and unbraced sleeves have made huge power. No less done incorrectly, pinning or adding block gaurds could actually cause you more problems. For 4-500whp I do not think you need any additional bracing, you would be better served with spending that money on tuning, fuel, and management.
you guys are all great,lots of opinions.i am know some people make in the 300whp range,myself my car dynoed 280.9 whp.would of done better if i had a perfect(nice clean bend).the tuner says fix down pipe and go to 3 inch exhaust,tune on e85 and i will make 400whp.that sounds good but how long will that last.thats if it dont blow up on the dyno.tuner is good i just dont think it will last.thanx again for all u guys info and opinions.
280whp to 400whp is a heck of a jump for fixing downpipe, exhaust, and retuning on e85. I would imagine it would take a good bit more boost to get you there as well.
Also if your talking 400whp on stock internals now, I would say your pushing it definately. If your talking 400whp on good internals with stock sleeve... go for it if you have a good tuner and such, I would at least.
Hmm I never found a block guard.
