possible crome iacv issue?
Old Dec 30, 2011 | 02:57 PM
eg6-jarhead's Avatar
Default possible crome iacv issue?
ive had this problem on 2 cars now.
symptoms:
cold start idle surge (1200rpm-1500rpm)
cel 14 (iacv)
feels like tps has dead spot from 0%-20% (sucks for cruising cause the throttle acts like an on/off switch)
once the engine comes up to operating temp the idle is perfect and it doesnt trigger the cel right away. it also wont act like there is a dead spot as often.
but once the cel comes on, the dead throttle spot is constant.
the cel will clear instantly if i cycle the key.
i looked around for this problem and didnt come up with anything..
in crome the idle controls are at 900rpm and 8% iacv compensation..nothing crazy i thought..
thanks,
jack
Old Dec 31, 2011 | 06:40 AM
7rrivera7's Avatar
Default Re: possible crome iacv issue?
Try cleaning the IACV with brake or carb cleaner. You could also test if the IACV is causing the TPS dead spot by disabling it in a P30/P72 or Gold map.
Old Jan 1, 2012 | 10:48 AM
thanks man i didnt know it could be disabled
ill try that
Old Mar 17, 2012 | 10:22 AM
THE PROBLEM WAS THAT THE INJECTOR RESISTOR BOX WAS WIRED INCORRECTLY.
FIXED
stopspazinout
20
Sep 27, 2008 06:16 PM
hon2984
Feb 8, 2008 03:22 PM
924doorEG
16
Nov 15, 2007 06:14 AM
blu3g
Sep 11, 2006 02:51 PM
mikeunreal2
14
Feb 9, 2006 01:51 PM
