milled turbo to accept 3" v-band?
Old Dec 30, 2011 | 06:32 AM
that-guy's Avatar
Default milled turbo to accept 3" v-band?
wasn't sure whether to put this in here or in the FI forum...I have a T3 .63 A/R PTE turbo sitting here and the only option for 3" was a 4 bolt, so i opted for the 2.5" v-band instead, i was wondering if anybody has, or if it is even possible, to throw the hotside on a mill, shave down the existing v-band, tapper/port the hole to 3", then weld in a stainless 3" v-band?
Old Dec 30, 2011 | 06:59 AM
b20vtech's Avatar
Default Re: milled turbo to accept 3" v-band?
what about a taper down pipe from 2.5-3" right where it exits out the hotside?
Old Dec 30, 2011 | 09:02 AM
that-guy's Avatar
i'm actually wondering if this will work, vice using a 2.5"-3" transition like most use
Old Dec 30, 2011 | 09:56 AM
HellaFab's Avatar
why didnt you buy the 3" 4 bolt and machine that? a 4 bolt 3" flange is pretty close to what you need.
people weld vbands onto turbo housings all of the time.
Old Dec 30, 2011 | 09:54 PM
k24em2's Avatar
Sure its possible, probably gonna be cost prohibitive though. Setting that up on a mill would probably cost more than just buying another housing
Old Dec 31, 2011 | 02:23 PM
sdubfid's Avatar
If you have a 3 jaw chuck on the mill it would take 10 seconds to setup
Best would be to just throw it on a lathe if you have one, then you could taper it too. If you want to get fancy you can make your new vband press into the housing and then weld it.
Old Jan 1, 2012 | 06:36 PM
turbo-2nr's Avatar
ya i think it would be a little to unbalanced to throw on a lathe
but should of went with the 4bolt and welded on a flange
Old Jan 1, 2012 | 07:20 PM
Jhicks's Avatar
sorry just trying to get my 5 posts
Old Jan 2, 2012 | 07:25 AM
HellaFab's Avatar
you must have a **** lathe.
just use an angle grinder and grind it dow. to weld a vband on if you wanna do it cheap.
Old Jan 2, 2012 | 08:39 AM
sdubfid's Avatar
How do you think they made it in the first place? We have 50+lb turbine housings that are spun on the lathe.
Old Jan 2, 2012 | 06:10 PM
k24em2's Avatar
This
I've got a big *** clausing that wouldn't give a rats *** about a turbo housing, a big box store lathe would not be fun to be around though
monster_c
Apr 12, 2012 03:50 AM
denraweb
Feb 22, 2008 06:20 AM
boostedgsr1234
Jan 13, 2008 07:20 PM
PreIudeSI
Jul 22, 2002 06:35 PM
dbman96
May 10, 2002 01:43 PM
