Turbo interchange between Mitsubishi?
Do all mitsubishi stock turbos have the same bolt pattern/design? I currently have a td04h (GSX Turbo) and I was wondering if I can throw like an EVO turbo on there with no problem. If I am correct the evo has the same housing, correct me if I'm wrong. So can I just remove my old turbo and slap on the EVO one?
Re: Turbo interchange between Mitsubishi? (denraweb)
The newer evo turbos I believe have a twin scroll flange. The older mitsu turbos have the 16b flange.
I think, not 100% sure.
Re: Turbo interchange between Mitsubishi? (RCautoworks)
your best bet would be to run a 20g if you want it to 'bolt in' you could also look at FP turbo's again.. Bolt in turbos.
Goodluck.
Goodluck.
