4 Bolt T3 discharge flange
New User
Hey has anyone measured the 4 bolt turbine? How large is the outlet, how large is the bolt circle for the flange? I've got plenty of scrap metal here at work, a bandsaw, and a drill press.
Re: 4 Bolt T3 discharge flange (dbman96)
i think the outlet diameter is 2.5", that is what the turbo shop i got it from said...i don't know the bolt circle
New User
Re: 4 Bolt T3 discharge flange (Quaalude)
If it's the same as the 4-bolt T4 flange it's 4.18" but I want to be sure. (my turbo is at home, I'm not)
you are going to cut that steal with a ban saw. i dont think that will work to well. you should be using steal thick enough to break any bansaw blade you use. correct me if i am wrong! i think you would have to use a plasma cutter
[Modified by CovertFI, 10:44 PM 5/10/2002]
hybrid_KJ
Welding / Fabrication
02-07-2005 04:20 PM
