HOW TO GET MORE PSI?
Old Dec 27, 2011 | 11:26 PM
DrewBrews's Avatar
Default HOW TO GET MORE PSI?
Sorry noob here, i got a turbo ls with a manual boost controller. i turned it all the way up but my max boost is 8 psi. How can i go higher? why am i limit to 8? i know turbo ls stock internals can at least handle 12 psi with good tune. Let me know Thanks.
Old Dec 28, 2011 | 12:06 AM
CO_RaceFab's Avatar
Default Re: HOW TO GET MORE PSI?
Either you have your boost controller lines routed incorrectly or you have a really weak gate spring I doubt this though... take your lines off completly and see what it makes.
Old Dec 28, 2011 | 05:34 AM
Bix VT's Avatar
12 psi on what turbo? HP is what you should be looking at for the limits of the stock block. what is the wastegate set to?
nealnanoHX's Avatar
PSI means nothing. I agree make sure you have the boost controller hooked up right.
Old Dec 28, 2011 | 08:59 AM
DrewBrews's Avatar
wastegate springs are set to 12 psi.
Old Dec 28, 2011 | 09:00 AM
DrewBrews's Avatar
just take off the lines that connects to the boost controller and leave it open?
Old Dec 28, 2011 | 10:55 AM
crvtectim's Avatar
If you have a 12 psi spring in the wastegate, just disconnect the mbc completely. Run a boost reference line from the compressor housing of the turbo to the bottom port on the wastegate. That should give you 12 psi, unless you have other issues such as boost leaks.
Old Dec 28, 2011 | 01:42 PM
TheShodan's Avatar
Moderator
Sounds like he has a boost leak somewhere if he's only getting 8psi of pressure, and the spring is set to 12psi (assuming he is sure that the spring is, in fact, 12psi.
Old Dec 28, 2011 | 02:42 PM
jasoncrashtech's Avatar
what color is the spring and how wide is it ?
Old Dec 28, 2011 | 04:23 PM
Garage Life's Avatar
what wastegate are you running? and what size is your turbo?
Old Dec 28, 2011 | 04:45 PM
DrewBrews's Avatar
i just took out the boost controller and it hit 12 psi. Thanks though
Old Dec 28, 2011 | 04:54 PM
DrewBrews's Avatar
50mm 12 psi wastegate and a t3/t4 50trim turbo
rickturboteg
Aug 28, 2006 05:36 PM
BlUAc
May 20, 2006 09:43 AM
FUP23
Sep 30, 2002 09:15 PM
Cyrio
Dec 4, 2001 07:00 PM
clean
Oct 18, 2001 11:16 AM
