b18b1 vs b18c1 a/c?
Old Dec 15, 2011 | 06:31 PM
augie1209's Avatar
Default b18b1 vs b18c1 a/c?
are the a/c components (compressor, ac bracket, lines, dryer, condensor) the same with these two motors? if so, will these all bolt up in a 97 civic (with c1 swap) if all used together?
Old Dec 15, 2011 | 08:44 PM
sebTeggy's Avatar
Default Re: b18b1 vs b18c1 a/c?
I installed ac from a 95 RS teg onto a 2001 Type R teg. Everything bolted up.
Although I am not sure about civic chassis, since they were mainly equipped with D series.
Although they might have their own unique B series civic a/c lines, I have a feeling that dc a/c setup will NOT bolt right up. I remember checking part numbers on oemacuraparts and didn't see too many similarities.
Technically, you could makeshift most of the lines, but you are better finding a del sol SIR a/c setup, since those came with b series motors.
Old Dec 16, 2011 | 04:48 AM
kyden's Avatar
you can't use the integra parts on the civic. just get a crv/del sol vtec a/c bracket and use your stock components.
Kendawg386
Aug 24, 2012 11:23 AM
assassinACE12
Aug 23, 2008 04:12 PM
crazyguy
12
Jun 10, 2007 01:45 PM
Mentat Ghola
May 14, 2005 05:48 AM
IMPORTMyth01
Apr 28, 2005 05:23 PM
