94 del sol ITR turbo a/c confusion!!!
So I got this del sol with ITR b18 type r swap in and it's boosting 5 lbs right now with an a/c compatible inline pro manifold. The itr swap came with the ac bracket and the b series compressor but I keep hearing a few different ways to hook it all up.
I've heard
1. Use some special mount that hasport makes that's like 200$
2. Use all d series brackets Amd mounts on the b series and just use the del sol ac lines
3. Use b18 compressor with a b20 Crv bracket
4. Use all the b series stuff with the del sol lines
And so on and so forth. And all the stuff I see is like 5 year old forums. I just need some straight and updated answers from people who are experienced.
Any and all help is greatly appreciated. Thanks!
I've heard
Re: 94 del sol ITR turbo a/c confusion!!!
Easiest way IMO is to get a CRV AC bracket that way you can use the D series compressor and AC lines. You can use the B series compressor and bracket but you will need to have the AC lines modified unless the Del Sol is a Vtec model and came with a B16.
Oh ok and this is guaranteed fit? Like from experience? I just dont wanna buy a ton of brackets and compressors trying each one ya know? That d series compressor bolts right up to the Crv bracket?
You can use a P30 or a P72 bracket. Only thing is only 3 bolts of the 4 from compressor to bracket will line up, but it'll hold fine. If you feel iffy about it, use lock washers. I did this for my cousin's car, no problems for almost a year and a half now. I even had him come by 3 weeks ago to double check the bolts and none of them have backed out.
Ya the car is a 94 del sol si. It had the d16z6 in it before I dropped the ITR in. Ok so I just need to My old d16 ac bracket and compressor?? That correct? And just one hold won't line up?
Ecky
13
02-22-2014 03:15 PM
JinDIESEL
09-03-2004 05:54 AM
