91 SI tranny wont shift in reverse
Old Dec 12, 2011 | 06:54 PM
StayTunedEf's Avatar
Default 91 SI tranny wont shift in reverse
i recently did a 5 speed swap in my 89 hatch and at first the tranny shift through all gears put it in reverse tested it it worked couple min later i went to take it out and it wouldnt go in reverse i thought it was my b*tch pin cause it was half broke so i replaced it and it work for one try then stoped now i cant get it into reverse at all its like hitting a wall but the car drives fine ??? idk what to do anyone got anything?
Old Dec 12, 2011 | 11:06 PM
~sp33~'s Avatar
EFB055
Default Re: 91 SI tranny wont shift in reverse
If it worked before, re check all your linkages. That's going to be the most likely problem.
Old Dec 16, 2011 | 06:22 AM
i think it might be the shift fork so im going to retear the tranny out and open it up cause its like its just hitting a brickwall no give at all
Old Oct 24, 2012 | 10:26 AM
hondatime1's Avatar
Did you find out cause?
~Bob
jvo8
Aug 11, 2024 07:12 AM
Ge-money
18
Nov 18, 2006 05:43 PM
DV98CVC
Feb 21, 2003 06:38 AM
DOHCarp
Jun 8, 2002 04:49 PM
