piston rods, are they worth the money to put in??
Old Oct 7, 2002 | 04:56 PM
95accordracer's Avatar
Default piston rods, are they worth the money to put in??
i got a hook up for a set of high performance piston rods for my 95 accord and everyone is telling me that i might as well buy a new h22a cause with the money i spend rebuilding the damn thing, i could just get a prelude engineI have everything replaced on the exhaust from the cold air intake to the manifold and the cat conv. to the exhaust, should i just go for the rebuild? and how much of a boost of horsepower am i looking at if i install them? . is it really worth it??
[Modified by 95accordracer, 1:57 AM 10/8/2002]
Old Oct 7, 2002 | 05:24 PM
niedejb's Avatar
Default Re: piston rods, are they worth the money to put in?? (95accordracer)
If youre going to stay NA...probably not worth it.
Of course the rebuild wont cost as much as the H22, but I doubt you get the 60 hp increase with pistons and rods either.
Old Oct 7, 2002 | 05:49 PM
Default Re: piston rods, are they worth the money to put in?? (niedejb)
yeah, i was planning on replacing the camshaft, and pistons with the rods. with all of that, how much of a HP boost would i be looking at?
Old Oct 7, 2002 | 06:25 PM
niedejb's Avatar
Depends on the compression/diameter of the pistons and the cam.
It could literally vary from -20 to +70 hp
Old Oct 7, 2002 | 10:30 PM
FastechAccord's Avatar
Niedejb, do you know if you have to resleeve the F22B1 to install pistons, or can you just hone the cylinders and install new pistons??
Old Oct 8, 2002 | 01:52 AM
niedejb's Avatar
Default Re: piston rods, are they worth the money to put in?? (EvoAccord)
You can hone if its within tolerances.
Stock size: 85.07 Max
.25 Over: 85.25-85.26
.50 Over: 85.50-85.510
Reboring limit .50 mm
(the over will require new pistons)
Straight from the service manual.
Old Oct 8, 2002 | 06:06 AM
SOHCArchangel's Avatar
remember kiddies the f22b1 has iron sleeves not that nikasil all the obdII motors have ^_^
Old Oct 8, 2002 | 06:57 AM
niedejb's Avatar
Default Re: piston rods, are they worth the money to put in?? (SOHCArchangel)
My F22b1 is OBDII
Old Oct 8, 2002 | 07:19 AM
My F22b1 is OBDII
errr
97 i forgot, nm
Old Oct 8, 2002 | 11:19 AM
I have built a couple of B series motors, however on the B series you can see the iron sleeve inside of the aluminum sleeve. On the F series, I can not see an iron sleeve. It just looks like one big aluminum sleeve. So, whats the deal?? These f series blocks are much different from the b series i am used to.
Old Oct 8, 2002 | 12:06 PM
Razor's Avatar
so whats your point?
Old Oct 8, 2002 | 12:35 PM
niedejb's Avatar
My F22b1 is OBDII
errr
97 i forgot, nm
You would have jumped all over anyone else that would've said that.
I'll let this one slide.
99black_em1
May 16, 2011 06:45 AM
Slimm-rw-
May 3, 2004 01:06 PM
the_0ne
Jan 17, 2004 07:14 AM
Rratedcivichatch
Sep 12, 2002 09:16 PM
B19CivicHB
Feb 18, 2002 06:14 PM
