Finally installed turbo kit today! HElP WASTE GATE WONT LET HOOD CLOSE!!!
Old Nov 24, 2011 | 03:14 PM
10psiLsEf2's Avatar
Default Finally installed turbo kit today! HElP WASTE GATE WONT LET HOOD CLOSE!!!
SO today i installed my turbo kit. since i am off FINALLY!
Put everything together (charge pipes.FMIC) etc....and my waste gate is top mount (log style manifold) i cant close my hood.
Any suggestions? is there short waste gates? can i run a pipe and relocate it? if so who sells them?
Old Nov 24, 2011 | 03:15 PM
91efbluehatch's Avatar
Default Re: Finally installed turbo kit today! HElP WASTE GATE WONT LET HOOD CLOSE!!!
see if you can have a like 90 degree bent to place the wastegate horizontal.
Old Nov 24, 2011 | 03:20 PM
10psiLsEf2's Avatar
What i was thinking but were can i purchase something like that?
Old Nov 24, 2011 | 03:25 PM
i dont know of companies, but i do know that they are made. i was going to get one for my gsr boost build, but im working on internals right now
Old Nov 24, 2011 | 03:36 PM
v4lu3s's Avatar
RTFM
exhaust shop maybe can weld one up. or you can cut your hood. or see abot a lower profile wastegate.
Old Nov 24, 2011 | 04:02 PM
BLU CIVIC's Avatar
Track Advocate
exhaust shop or order an elbow and 2 flanges
Old Nov 24, 2011 | 04:32 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
OR you can cut the webbing on the hood. This has been done plenty of times. Some cars it lightly hits still some it doesn't - either way you will be able to close the hood.
Old Nov 24, 2011 | 05:16 PM
10psiLsEf2's Avatar
Ive done this before but this manifold is fuccing wierd the waste gate is hitting on the hood and theres no webbing were its hitting, so theres nothing to cut
Old Nov 24, 2011 | 05:18 PM
DO IT ON ALL FOURS
Interesting indeed... Looks like it's Piping for you then. Just ride around with your hood off for now so you can flaunt your new setup.
Old Nov 24, 2011 | 06:24 PM
10psiLsEf2's Avatar
HELL NO
cops in orange are lil fugging Biotches!!!! or i would + its my daily driver
Old Nov 24, 2011 | 06:31 PM
crvtectim's Avatar
Smaller wastegates are made. If you're not running a boost controller, you can also remove the barbed fitting from the top of the wastegate since you only need a pressure source connected to the bottom fitting. That could give you another 1/2" of clearance.
Old Nov 24, 2011 | 07:19 PM
10psiLsEf2's Avatar
tried it and it can close with washers on the rear! but that would mean if i removed the barbed fitting i would need a ten pound spring if i wanted to do 10 pounds right?
Old Nov 25, 2011 | 05:12 AM
BLU CIVIC's Avatar
Track Advocate
i used a 10.1psi spring and my max boost pressure was 9.2psi. if you're using a Tial wastegate, i'd go with the 11.6psi or large red spring if you wanted to run around 10psi
Old Nov 26, 2011 | 06:07 AM
DO IT ON ALL FOURS
Wow now this is just getting out of hand...
You guys really need to read up and RESEARCH... (this has only been covered - oh, a MILLION TIMES) You can "throttle" the incoming boost signal with a valve. You can get fancy and purchase a good name brand Manual Boost Controller or go low end and use a fish tank valve (not recomended)... or obviously anything in between. You don't need to put ANYTHING on top of the wastegate unless you are using an Electronic Boost Controller. Use the side port (make sure all the other side ports are blocked off) and regulate the incoming line. Leave the top port open to atmosphere. Now don't get me wrong, that doesn't mean you can take a 5lbs spring and make it run 50 psi of boost... It's all about making sure there is no spikes no matter what setup you are running. You can use a 5 or 7lbs spring and achieve 10 psi no problem.
You have to understand - while the exhaust is under pressure it isn't like a compressor. Why do you think they are called compressors and turbines? The turbine essentially operates off of flow and pressure differentials help this greatly. Compressors take air and compress them (imagine that) to fit an even more dense charge of air for the engine. Therefore you let more flow to the turbine by not allowing the wastegate to open - thus forcing the compressor to spin faster and sucking even more air into the same given area - hence more psi (Pounds per Square Inch). So restricting boost to the wastegate has the same exact affect as running a larger spring. If you have enough exhaust pressure to open a 5lbs wastegate spring on its own you have MAJOR problems.
PS - This is just the watered down version of explanation - if you still don't understand I can break it down for you even more...
Old Nov 26, 2011 | 06:56 AM
BLU CIVIC's Avatar
Track Advocate
i think you must have been referring to your post. don't think he asked for an explanation of how a turbo works or boost controllers. asked a simple spring question and then you had to go all Bill Nye the Science Guy
Old Nov 26, 2011 | 07:45 AM
DO IT ON ALL FOURS
Clearly there is a lack of fundamental knowledge by the both of you. Everyone should know how a turbo, wastegate, and blow off valve work if they are going to have a boosted setup. How in the world can you say - of if you have a Tial wastegate and you want to run 10psi you need to use this spring... Obviously you lack the knowledge just as much as the OP. clearly wastegate placement has a lot to do with how it will act. Turbos are never a "one size fits all" application. Just because it worked on your setup doesn't mean his will act identically... Oh well - if you need further explanation let me know by saying dumb things - I'll get the hint.
Old Nov 26, 2011 | 09:43 AM
BLU CIVIC's Avatar
Track Advocate
yeah yeah yeah, every set-up no matter how identical you try to make it will always produce different number and there's a ton of variables, blah blah blah. Giving someone a generalized answer to their question doesn't mean they're ignorant of how a turbo and its components work
Old Nov 26, 2011 | 05:05 PM
CRX-Kid11's Avatar
http://www.ebay.com/sch/i.html?_from...All-Categories
Old Nov 26, 2011 | 05:46 PM
BLU CIVIC's Avatar
Track Advocate
that would be a negative. buying a pre-made dump tube almost always never works out. better to get one made
Old Nov 26, 2011 | 06:32 PM
crvtectim's Avatar
I think the link was posted to show the wastegate elbow.
Old Nov 26, 2011 | 10:57 PM
10psiLsEf2's Avatar
LOL
Old Nov 26, 2011 | 11:18 PM
ghosthatch's Avatar
there are 45 degree relocation kits... but it seems they are only in europe. but you can purchase em on ebay too... only one ive seen
Old Nov 27, 2011 | 05:12 AM
CRX-Kid11's Avatar
link was to show there are premade elbows out there for cheap
Old Nov 28, 2011 | 04:39 AM
BLU CIVIC's Avatar
Track Advocate
they're out there for cheap but may not have your wastegate turned the proper direction. i had one of those kits and it didn't work for me at all. call greg at go-autoworks and he can get one made for you. i like them b/c they test fit on an engine first. still, cheaper route may be just to go to an exhaust shop
Old Nov 28, 2011 | 10:46 AM
Nooch's Avatar
HELL NO
Damn what's your setup? I live close by and wouldn't want to risk half of what you're doing haha.
allanonjj
23
Jun 2, 2005 07:21 AM
B18C1Crusader
Feb 11, 2005 07:51 PM
VtecAdil
Oct 14, 2004 10:44 AM
zippeay
Aug 22, 2003 10:16 AM
its WANG yoO
Sep 5, 2002 04:37 PM
