Fuel Pressure Regulator bad??
Hi guys.. a little question here..
can u tell me if my Fuel Pressure Regulator id bad??
i make that question because if the engine is running and i disconect the vaccum hose attached to it, nothings happen.. the engine still running and nothing change.. is it bad?
because i hav a very serious problem with my idle and i dont know what more to do... :S i have replaced EACV, FITV, TPS, my ecu is new, ECT, clean Throttle body, good PCV, no vaccum leaks and i still getting very very low idle speed and my car is eating a lot a lot!! of fuel..
i do a video about the idle, look it
http://www.youtube.com/watch?v=_2oSV...layer_embedded
i do a video about the idle, look ithttp://www.youtube.com/watch?v=_2oSV...layer_embedded
Did you do any of the things suggested in this thread?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-95-coupe-idle-deceleration-c-mpg-problems-pls-help-2997880/
Specifically "Check the timing with a timing light"? I don't see where you mentioned that you did that. Replacing random parts hoping to fix the issue is not smart and very expensive.
i already do that, but my question is, why the low idle only happen when the engine warm up, if it cold and A/C is turn off it run very nice.. but when it gen warm the low idle appear
jetlude
Jul 7, 2007 09:16 AM
