LS turbo with meth inj
Old Nov 22, 2011 | 01:17 PM
jdm_2.2eg's Avatar
Default LS turbo with meth inj
Ok I searched alittle and couldn't find a clear cut answer so Ill just throw it out and hope I don't get flamed horribly.. Ok I have a 94 LS stock head stock block with gsr tranny
Pte sc34
Inline cast mani
Tial 38
walbro 255
RC 440s or 400 something
greddy fmic
most of the supporting mods to safely daily.. well the car has been dailyed for like 20k miles and zero problems..It was tuned on 10lbs and made like 300ish well I was wondering if I threw a nice meth/alky kit and took it back and got it tuned again would I be able to safely run around 14 psi or even go high if it tunes safely etc? anyone chime in with similar setup thanks
Old Nov 22, 2011 | 01:28 PM
sebTeggy's Avatar
Default Re: LS turbo with meth inj
10psi will last for 20k miles
14psi might not, I thought the rule of thumb was dont go over 8-11lbs without sleeving?
Old Nov 22, 2011 | 03:13 PM
mouab18c1's Avatar
Untrue, my brother in law ran 30lbs on a SOHC Vitara setup with stock sleeves. Ran a 11.3
For the OP why do you want meth inj? I would go with e85 first
Old Nov 23, 2011 | 06:51 AM
jdm_2.2eg's Avatar
aww rode in a vitara d series before haha.. junkyard brawlin... So I jus wanna turn the boost up a few pounds maybe get me to like 350 status jus alittle more to play with.. this is jus a daily driver..
Old Nov 23, 2011 | 07:28 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
There really aren't any rules of thumb, each motor is really created and built differently and so goes the same for tuning.
I would honestly invest in some internals for the motor such as pistons and rods because you will always want more power and at least a stout bottom end will support more down the road.
Old Nov 23, 2011 | 11:24 AM
mouab18c1's Avatar
It was a Daily Driver
Old Nov 23, 2011 | 12:52 PM
jdm_2.2eg's Avatar
Ok.. that will answer my itch for now then.. Ill just leave it alone for now haha... I don't wanna build it I am going to buy a K24 off kmod down in NC or whatever... I had a spare meth kit laying around I was gonna throw it on cuz I know with race gas I can turn the boost up and Meth almost make its race gas octane numbers I thought.. But alright cool deal
Old Nov 24, 2011 | 05:57 AM
Schister66's Avatar
Man U FTW
For starters, your injectors won't make any more power than they already do. If you're at 300whp with 440cc injectors, consider yourself lucky.
Moving on, alcohol/methanol injection works to cool the intake charge so that more power can be made on a certain grade fuel. If the option to upgrade fuels is available (say 92oct to 110oct) then there is no need for alc/meth injection; similarly, your car isn't maxing the fuel its using. On straight 92oct, your setup will be able to make more power, but your engine is a different story...it might not.
If you want to make more power, get a larger set of injectors (720cc), a 3bar MAP sensor and a retune. No need to complicate things with Alc/Meth
That's not really how it works. This whole issue has to do with the heat/pressure generated in the intake charge. Whether that heat is brought in as a byproduct of compressing the air in the turbocharger at high boost OR the heat is due to the large volume of air in the cylinder being compressed, it poses the same problem. A certain fuel, say 92 octane for this example, can only handle so much pressure/heat before it spontaneously combusts without the aid of a spark. This causes big problems inside an engine. Methanol/Alcohol injection uses a phase change (liquid to gas) to absorb the heat out of the intake charge. There is no effect on the octane rating.
Old Nov 25, 2011 | 11:48 AM
jdm_2.2eg's Avatar
Thanks... I guess I am gonna just build a K series and have all motor... I was thinking that around 11 psi on my setup was maxed so I could throw the meth inj to come in around 10psi and maybe get around 14 but I understand what your saying my fuel will be burning up due to the heat before the spark comes in possible making detonation...Forged pistons and stronger rods woud come into play what I am trying to stay away from because I am not trying to make this a project car
Old Nov 27, 2011 | 05:07 PM
KeseK24RSX's Avatar
What stage K24 were you intersted in?
-Marquis
-KMOD Performance
Greensboro NC
fickel_8
Nov 10, 2006 01:27 PM
JDM turbo DC
Feb 14, 2006 11:14 PM
Ls-Turbo
Oct 26, 2005 04:42 AM
123Four
Jun 8, 2005 10:41 AM
sExy_TinKY
Sep 7, 2003 07:37 PM
