how many lbs are u boosting..??
Old Oct 25, 2005 | 09:40 PM
Ls-Turbo's Avatar
Default how many lbs are u boosting..??
how many lbs r u boosting in ur stock ls block.. how long have u been doing it and wats ur setup.. iam doing 6lbs just seeing how high i can go..
Old Oct 25, 2005 | 09:59 PM
JDM00SI's Avatar
Default Re: how many lbs are u boosting..?? (Ls-Turbo)
my buddy made 300whp on 13psi on stock internals using sc61, and it was his daily driver untill he got rid of it. he drove it each day at least 25 miles.....
Old Oct 25, 2005 | 10:21 PM
Ls-Turbo's Avatar
Default Re: how many lbs are u boosting..?? (JDM00SI)
tight
Old Oct 25, 2005 | 10:29 PM
Blackack26's Avatar
https://honda-tech.com/zerothread?id=1323059
has lots of info
Old Oct 25, 2005 | 10:48 PM
Ls-Turbo's Avatar
Default Re: how many lbs are u boosting..?? (Blackack26)
thanks ive seen that already ..
Old Oct 25, 2005 | 11:48 PM
1turbodc2's Avatar
psi is going to vary with each set up so your question won't really be answered, what turbo do u have??? i have a greddy turbo kit on my 01 gsr and i am boosting 10 psi, with 450cc injectors
Old Oct 26, 2005 | 12:12 AM
adseguy's Avatar
Default Re: (gssr)
problem with this question is that it really doesn't matter AT ALL. I can EASILY push 20PSI on my stock block with a giant turbo even. If the timing isn't there to make the power then the internals really aren't stressed except for excess heat, but the block will take it. It's not how many lbs are you running, but more how much HP and what is the timing like. I have pushed 19PSI on my block before, but timing was so safe it was stupid. Remember also a small turbo pushing 15-16PSI might be safer then a big turbo pushin on 9PSI because the bigger turbo will make ALOT more power. I hope everyone understands this and this thread ends
Old Oct 26, 2005 | 12:51 AM
f1 vtec's Avatar
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">problem with this question is that it really doesn't matter AT ALL. I can EASILY push 20PSI on my stock block with a giant turbo even. If the timing isn't there to make the power then the internals really aren't stressed except for excess heat, but the block will take it. It's not how many lbs are you running, but more how much HP and what is the timing like. I have pushed 19PSI on my block before, but timing was so safe it was stupid. Remember also a small turbo pushing 15-16PSI might be safer then a big turbo pushin on 9PSI because the bigger turbo will make ALOT more power. I hope everyone understands this and this thread ends </TD></TR></TABLE>
i agree
i was just going to say the same. 15psi on a small turbo is not the same as 15psi on a larger turbo, so on this thread your going to get numbers varying from like 5-20psi, in this case its not the amount of psi but the amount of whp u are aiming to get out of the setup is what you should be looking in to.
Old Oct 26, 2005 | 04:31 AM
T-RO's Avatar
14 gajillion...
Old Oct 26, 2005 | 04:33 AM
Fenrir51's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">14 gajillion...</TD></TR></TABLE>
But you still had 100ft/lbs torque?
Old Oct 26, 2005 | 04:39 AM
ginoboy1978's Avatar
Default Re: (Fenrir51)
5lbs, stock D16y8, getting 180 whp, T3 dual BB turbo
But like everyone said above, can't really measure how much an engine can handle....... by pounds of boost.
DAN
Old Oct 26, 2005 | 04:42 AM
Arturbo's Avatar
Better than steak
25 Year Member
I am running 4 quater pounders from McDonald's, which would be 1lbs. I guess?
jdm_2.2eg
Nov 27, 2011 05:07 PM
beantowncoupe98
Jan 10, 2011 08:44 PM
OneCamBoostin
Oct 24, 2008 08:40 AM
phoQ
28
Apr 4, 2005 01:53 PM
joek84
Nov 2, 2003 03:20 AM
