Suspension & Brakes Theory, alignment, spring rates....
why does my skunk2 camber kit keep loosening while driving
Old Nov 22, 2011 | 06:40 AM
swizz977's Avatar
Default why does my skunk2 camber kit keep loosening while driving
only the passenger side keeps loosening up how is this possible is it actually jumping the threads?? or is it just spinning around loosening itself its the 88-00 civic ones
Old Nov 22, 2011 | 07:41 AM
grumblemarc's Avatar
The Grumpiest
Default Re: why does my skunk2 camber kit keep loosening while driving
Because it's junk.
Old Nov 22, 2011 | 09:51 AM
TPB's Avatar
TPB
Originally Posted by grumblemarc
Because it's junk.
I wouldn't go so far as to say that. I've been running them for years without any issues. A year ago I had a really hard hit in the tire wall during a road race (side and rear) at 140 km/h and the uca's didn't budge... maintained alignment. Mind you these are the newer pro series balljoints that adjust from below.
Old Nov 22, 2011 | 10:31 AM
The Grumpiest
Some people seem to have better luck than others with S2 products.
Old Nov 22, 2011 | 11:37 AM
EsotericImage's Avatar
Retired Moderator
the lower model ones arent the best quality..this isnt a secret.
try the better version. I have heard they perform alot better.
personally, i have buddy clubs and work flawlessy
Old Nov 22, 2011 | 04:43 PM
swizz977's Avatar
im talking about the rear upper arms its getting looser and looser on my passanger side almost positive now
Old Nov 22, 2011 | 06:10 PM
The Grumpiest
"Rear upper arms"?
Old Nov 22, 2011 | 06:16 PM
TPB's Avatar
TPB
Are there lock nuts on each end of the arm to stop it from rotating and changing camber? I would scrap those unless S2 replaced the bushings with another material... those were definitely garbage bushings.
Take a picture of the arm so we can see.
Old Nov 23, 2011 | 06:06 AM
swizz977's Avatar
Old Nov 23, 2011 | 06:07 AM
swizz977's Avatar
its just backing itself out its not jumping threads cuz i tightend it up to the exact same spot as it was but this time i tightened the locking nut better i think.. well c in 2 days
Old Nov 23, 2011 | 07:36 AM
TPB's Avatar
TPB
It looks like you're missing the jam/lock nut on the inboard side so until you've fixed that, you'll continue to experience this problem.
Old Nov 23, 2011 | 08:21 AM
98civdx's Avatar
Master Detailer
I agree. OP, google a picture of a skunk2 camber kit if your un sure of what we're talking about. Or, look at the other side.
Did have a shop install it?
Old Nov 23, 2011 | 12:47 PM
swizz977's Avatar
no i had to take one off because i need more negative camber.. i had both the nuts off before with no problems but too much camber so i put one back on.. idk.. the other side is fine well c what happens
Old Nov 23, 2011 | 01:16 PM
The Grumpiest
So it's installed improperly and you're wondering WHY it's malfunctioning? Jeez.
Old Nov 23, 2011 | 01:38 PM
wannaBjdmca6's Avatar
you have more room on the other side. so move the adjuster and locking nuts toward the outside of the car.
and the above post is win.
why would you need more neg camber? Rcomps?
Old Nov 23, 2011 | 01:46 PM
The Grumpiest
Maybe this would explain it.
hey i just orderd some xxr 527s there 8.25 15 inch and i am getting 165 45 15's there federal formoza fd1.. i have an eg hatch im pretty sure i need a camber kit for these to fit in right.. i was thinking eather buddy club or k sport or skunk2.. i have been researching a lot but if you guys could help me with this set up thanks
Old Nov 23, 2011 | 02:05 PM
TunerN00b's Avatar
Never before have I seen someone else on here as worthy of their screen-name.
Old Nov 23, 2011 | 02:23 PM
swizz977's Avatar
lol hold on http://www.stanceworks.com/forums/sh...ad.php?t=23577
Old Nov 23, 2011 | 02:32 PM
The Grumpiest
So you can't post pictures of your OWN car?
Old Nov 23, 2011 | 05:49 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Please for the love of God ur not running a 165-45-15 size tire on a 8 inch rim.....
Old Nov 23, 2011 | 06:04 PM
98civdx's Avatar
Master Detailer
The other side has no lock nut as well?
Those nuts are there for a reason, buddy.
Old Nov 23, 2011 | 06:17 PM
donut.'s Avatar
wow.
"i took off the nuts that keep my camber kit from loosening, but why is it loosening?"
****ing facepalm
Old Nov 23, 2011 | 06:20 PM
HT Black OPs
****ing facepalm indeed
Old Nov 23, 2011 | 07:37 PM
totz's Avatar
replace it with other brands
Old Nov 23, 2011 | 08:05 PM
98civdx's Avatar
Master Detailer
Did you even read the thread?
other the bushings, there is noithing wrong with the camber kit. The issue is souly the OP's fault.
