Turbo max power rating
Old Nov 14, 2011 | 09:29 AM
Fnix's Avatar
Default Turbo max power rating
If I have a 300hp goal would I want a turbo supportable to 320hp vs 375?
I'm confused as to how close I need the supportable limit to to my goal.
Old Nov 14, 2011 | 11:42 AM
TheShodan's Avatar
Moderator
Default Re: Turbo max power rating
Engine Specifications, use of the car, max rpm, type of flange for the turbo used, what fuel? GOTTA BE SPECIFIC TO GET EVEN A GENERAL ANSWER TO SUCH A VAGUE QUESTION LIKE THAT.
Old Nov 14, 2011 | 11:46 AM
Fnix's Avatar
Well to put it simple I notice alot of people using 475hp supportable turbos for 300 horsepower goals vs turbos supportable of 320-350hp. Wouldnt that just give them wasted power and slower spooling?
Old Nov 14, 2011 | 11:49 AM
TheShodan's Avatar
Moderator
No. not necessarily. It all depends upon the questions I stated above. Its not that simple. If they are going for higher levels later, then no. you never want to use a turbo with a horsepower goal in which you're using the turbo at its maximum.
Most here use larger turbos than even needed because they drag race, in which they truly believe they need and want more power. But again, it depends upon turbo used and engine platform.
CanadianEF9
Feb 10, 2011 03:42 PM
Discosteak
Sep 28, 2005 09:15 AM
CivicSmkYa21
May 19, 2004 10:06 AM
krings
May 9, 2003 01:26 AM
1BadLude6986
Oct 12, 2002 02:47 PM
