No start after stalling engine. distributor and rotor replaced 1/2 hr prior
Old Nov 11, 2011 | 07:36 PM
MinimusMaximus's Avatar
Icon3 No start after stalling engine. distributor and rotor replaced 1/2 hr prior
OK. Wtf?
95 civic coupe: installed a new distributor cap and rotor after work and drove around town to run arrands. As I was looking for an address on a building I stalled the car. Went to restart it and nothing. Cranks over and over.
Because the car just stalled (clutch dump) I instinctively tried restarting it. Then I thought oh god timing belt! If so it's too late now, so as part of the roadside troubleshooting I looked inside the oil filler cap and can see the rockers moving as the eng7ine turns.
But the main thing is I got no spark. Pulled the plug wire and stuck a Phillips in the boot and grounded it.
Is there something cap and rotor related that could cause this? I literally changed it 1/5 hr before the car died.
I replaced the timing belt less than 2k miles ago. Car ran wonderful all up until I stalled it. Now it won't start.
Old Nov 12, 2011 | 12:15 AM
Nooch's Avatar
Default Re: No start after stalling engine. distributor and rotor replaced 1/2 hr prior
Could be the rotor has already fallen off.
Old Nov 12, 2011 | 12:43 AM
rickyracer's Avatar
check to make sure the screw that holds the rotor didn't fall out. happened to me 1 time and the screw fell to the back and damage the distributor.
Old Nov 12, 2011 | 07:33 AM
Nope. That was the first thing I checked. Rotor is fine, screw is where it's supposed to be.
Old Nov 12, 2011 | 07:47 AM
94EG8's Avatar
Seagull Management
If you still have the old cap and rotor try them, sometimes the button sticks in the cap. Other than that check the coil and igniter.
Alexander Smets
Jun 21, 2019 11:49 PM
MegaTwinky
Jun 7, 2012 11:44 PM
LS_Integra_94
Mar 14, 2007 07:15 PM
toben
14
Jan 31, 2007 12:13 PM
MAXFLOW2
Feb 23, 2005 11:50 PM
