z6 crank in y8 block turbo build how would this work
would a z6 crank in a y8 block and y8 head with a z6 oil pump work. i want to do this because the y8 crank is said to have oil problems...also how would it affect cam timing...what kinda power can safely expect with supertech 75.5mm pistons 9:1 with eagle rods...ported head... and turbonetics 50 trim.. all proper fuel.
way to many noob questions
if you use a y8 block w/ z6 oil pump and crank you will not have a dipstick tube
buy a z6 block or just port n shim the y8 and call it a day...i wouldnt worry so much unless you plan on very high rpm's
