Harmonic balance pulley or a oem
Re: Harmonic balance pulley or a oem
Check these out if ATI or Fluidampr are too expensive!
http://www.optionsauto.com/products.asp?dept=10300
You really can't be bothered can you ? At least make some effort if you want people to give you advise.
Anyway, my advise will most likely be this : If you have plenty of cash and are not afraid to spend it then go for the ATI. I'm not sure how much a new OEM pulley costs over there but i'd advise replacing it as a minimum if fund are low. Balancing the bottom end is important to BUT harmonic's and balancing are two completely different kettles of fish. I'm not saying a out of balance bottom end won't create its own harmonic's though...
84mm darton mid sleeved ls block
Cp piston 9.1
Bisi steel h rods
Stock ls crank
B16 head
Supertech valvetrain
Afi turbo intake manifold
70 mm skunk2 throttle body
Idi 2000 injectors
2 walbro fuel pump
Go autoworks top mount turbo manifold
Tial bov and wastegate
Full race back door intercooler
I'm just wonder if it would be a good idea to run the oem cranks pulley .
Cp piston 9.1
Bisi steel h rods
Stock ls crank
B16 head
Idi 2000 injectors
2 walbro fuel pump
I thought my car was a freak, it has done this numerous times! i finally got it down to having it at just he right tension.
Are they really that bad? I practically get wholesale price on Professional Products so was gonna try them out. They're IM and TB work great, I've used them on a few projects, so I figured the harmonic balancer would be good too.
Yes there junk, OEM is 10 fold better than one of those things.
OEM or ati IMO. the race version isnt needed for 700 or less but any more then that i would def run a race version. the ati street version is still lightyears better than a stock unit and plenty people run stock units on high powered cars
