civic wont turn over
Old Nov 7, 2011 | 08:54 AM
Turbolsvtech's Avatar
Default civic wont turn over
civic wont start car does absolutely nothing when trying to crank. If I turn the key to on the main relay goes through its setup one click then fuel pump primes the second click. Then the cel goes off third click but then i try to turn it over and nothing. The clutch switch is bypassed and jumped and i replaced the starter relay. The battery is good I checked the starter itself and the connections the fuses are good new ignition harness and ignition anything else im missing to check?
Old Nov 7, 2011 | 09:33 AM
Kohen's Avatar
Default Re: civic wont turn over
motor? what CEL? more information if you want people to help.
Old Nov 7, 2011 | 10:28 AM
apexi_rsx's Avatar
check and clean your motor grounds and try again
Old Nov 7, 2011 | 10:31 AM
ls vtech b18b1 with b16a head and check engine light= cel tried the grounds
Old Nov 7, 2011 | 10:36 AM
QuatroAce's Avatar
Are you getting 12V at the starter?
Old Nov 7, 2011 | 12:31 PM
Hanmin's Avatar
Try jumping it from the starter. If that works then check your ignition switch.
Old Nov 7, 2011 | 02:19 PM
frankenghia's Avatar
Check your clutch switch (neutral safety switch). Make sure it didn't break the tip off.
Old Nov 7, 2011 | 05:04 PM
vinem1's Avatar
So what happened?
Old Nov 11, 2011 | 06:06 AM
thangnhocngheo's Avatar
Check if u have sparks from the sparkplug and check if u have fuel.. **** happens.. I havent fix my problem yet.. No power to the fuel injector and no power to the dizzy... I check all the fuses and swap out 5 ecu.. Still no good.. Giod luck
Old Nov 11, 2011 | 06:08 AM
Go_Race_Your_Self's Avatar
Two Piece
This.
Kev
Old Nov 11, 2011 | 06:12 AM
RockStarKick's Avatar
Re check the bypass you have on the clutch safety switch, I had a jumper wire in mine at one time and it fell out..
Old Nov 14, 2011 | 10:17 AM
ok i checked the clutch safety its fine i replaced the starter relay with a new one. I replaced the ignition relay. I think my ignition switch went out and its not sending the 12 to the starter cause i can easily jump the starter to start the car
Old Nov 14, 2011 | 12:40 PM
Is there a fuse for that ?
Old Nov 23, 2011 | 02:46 AM
j23civicsi's Avatar
Any luck? I'm having the same problem as you.
Old Nov 23, 2011 | 03:59 AM
grumblemarc's Avatar
The Grumpiest
What have you done to troubleshoot?
Old Nov 23, 2011 | 06:51 AM
j23civicsi's Avatar
I've bypassed clutch switch, tested battery, checked voltage to starter-good, checked voltage to solenoid w/ key turned to start position-no power, all fuses good. Haven't checked ignition switch or starter relay yet. Where is the starter relay?
EKnewit
Jun 10, 2018 09:12 AM
jimmysteezen757
10
Jan 2, 2012 05:50 PM
obuhmyuh
10
May 4, 2010 02:15 PM
rodvang
23
Nov 5, 2005 05:57 PM
EG93si
Sep 15, 2005 09:10 PM
