civic wont turn over
civic wont start car does absolutely nothing when trying to crank. If I turn the key to on the main relay goes through its setup one click then fuel pump primes the second click. Then the cel goes off third click but then i try to turn it over and nothing. The clutch switch is bypassed and jumped and i replaced the starter relay. The battery is good I checked the starter itself and the connections the fuses are good new ignition harness and ignition anything else im missing to check?
Re: civic wont turn over
Check if u have sparks from the sparkplug and check if u have fuel.. **** happens.. I havent fix my problem yet.. No power to the fuel injector and no power to the dizzy... I check all the fuses and swap out 5 ecu.. Still no good.. Giod luck
ok i checked the clutch safety its fine i replaced the starter relay with a new one. I replaced the ignition relay. I think my ignition switch went out and its not sending the 12 to the starter cause i can easily jump the starter to start the car
Is there a fuse for that ?
I've bypassed clutch switch, tested battery, checked voltage to starter-good, checked voltage to solenoid w/ key turned to start position-no power, all fuses good. Haven't checked ignition switch or starter relay yet. Where is the starter relay?
jimmysteezen757
10
01-02-2012 05:50 PM
EG93si
09-15-2005 09:10 PM
