what hose goes here on the back of the gsr block?
Old Oct 31, 2011 | 09:13 AM
94_civic_dx's Avatar
Default what hose goes here on the back of the gsr block?
what hose connects where i circled in red or can i jus cap it off
Old Oct 31, 2011 | 09:17 AM
Default Re: what hose goes here on the back of the block?
forgot to mention its a gsr block
Old Oct 31, 2011 | 09:19 AM
Kohen's Avatar
might wanna get a bigger picture and pull the camera back a little bit.
Old Oct 31, 2011 | 09:22 AM
Wrona's Avatar
its above an oil filter looks like you can see the cheap *** fram filter
Old Oct 31, 2011 | 09:59 AM
Former User's Avatar
Originally Posted by Wrona
...oil filter looks like...the cheap *** fram filter
I use the Fram Tough Guard filter, which seems to be fine as indicated by its construction.
Old Oct 31, 2011 | 10:09 AM
Default Re: what hose goes here on the back of the gsr block?
Pic was taken wit my phone can try o make it bigger but idk...n ya it's above the oil filter but I've never seen one before on ne of my other b18 blocks
Old Oct 31, 2011 | 10:25 AM
jdmcertified909's Avatar
yup dont trust fram at all. wix is one of the best one found at napa. 100% more trustworthy http://www.youtube.com/watch?v=rIx4Y3TvAPk
Old Oct 31, 2011 | 10:40 AM
kyden's Avatar
the one in red goes to your heater core. what happened to the nipple next to it?
Old Oct 31, 2011 | 11:05 AM
Thanx So I should jus be able to plug it off cause I have no a/c controls in my car and as far as the nipple next to idk that's how it was when i got it
Old Oct 31, 2011 | 11:10 AM
kyden's Avatar
sorry i thought the filter was on the right side. that connection is for the oem oil cooler which is removed for whatever reason on your motor.
Old Oct 31, 2011 | 11:21 AM
Deetz's Avatar
Crazy Honda Guy
yes, i'd agree, it looks to be a hose missing from the oil cooler found on some gsr blocks that have it mounted behind the oil filter itself
PS- it looks like in your pic (hard to see, that that engine has an aftermarket sandwich plate mounted in behind your oil filter)
Old Oct 31, 2011 | 03:47 PM
Yea it has a sandwich plate on it for the turbo line fittings
Old Oct 31, 2011 | 04:22 PM
Hidenplanvew's Avatar
oil cooler
Old Oct 31, 2011 | 07:12 PM
So can I jus cap it off or wat do I do??
Old Oct 31, 2011 | 07:21 PM
NotAJDMFanBoy's Avatar
Loop the lines or get the oil cooler, or get a 96-01 water pipe.
Old Nov 1, 2011 | 06:10 AM
When u say loop the line wich lines are u talking about and what would a 96-01 water pipe do for me cause I have one off my old ls motor
Old Nov 1, 2011 | 06:56 AM
Deetz's Avatar
Crazy Honda Guy
Here is a picture of a stock b series oil cooler and water pipe to give you an idea.....
Old Nov 1, 2011 | 07:50 AM
So basically I gotta get a stock oil cooler??can I jus plug it or is it needed to have?
Old Nov 1, 2011 | 08:10 AM
94eg!'s Avatar
#1 Super Guy
Loved
This oil cooler is standard on P72 block motors (GSR & ITR and CTR). They didn't come on the B16As (at least in the US). You can't really install one if you've already got a sandwich plate, but you should probably run an external oil cooler instead. Especially if you are turbo.
ninety-five_DB
Jul 8, 2006 05:03 PM
asubennett
Apr 13, 2006 04:06 PM
ActiveAero
Oct 2, 2005 05:03 AM
Vsm Hatch
Aug 26, 2004 07:16 PM
streetlvlhatch
Feb 23, 2004 06:26 PM
