B16a 350 whp?
Old Oct 29, 2011 | 07:17 PM
Salvatorie's Avatar
Default B16a 350 whp?
Hello all. Im wanting to get 350+whp out of my b16a and im wondering the best route to take. Budget is slim but i know that im going to go with JE pistons, Eagle H-Beam rods and without a doubt im going to boost it. And here is where i want some opinions on the setup that will get me to 350+whp.
Old Oct 29, 2011 | 07:21 PM
tam4511's Avatar
Default Re: B16a 350 whp?
For 350 turbo is the only way to go. do a lot of research.
Will this be a DD car?track car? drag car?
Old Oct 29, 2011 | 11:26 PM
doood's Avatar
been there done that
You can make that on a stock block with the right turbo and a good tune
Old Oct 31, 2011 | 05:09 AM
Salvatorie's Avatar
This will be a 100% track car.
Old Nov 4, 2011 | 02:30 AM
Lil_Teg555's Avatar
Be on the safe side sleeve ur block its a must...
Old Nov 4, 2011 | 02:46 AM
Dioxine's Avatar
350 on stock stock block is fine. Get a block guard or post the block if your worried about it. If your only taking it to the track it should be fine. Turbo is the way to go. Do reseach!!!!!!!!!!!!!!!Make friends with the search bar.
Old Nov 4, 2011 | 03:47 PM
adriaticDB7's Avatar
Post up the progress!
Old Nov 4, 2011 | 07:26 PM
tam4511's Avatar
no its not, don't post info that you don't know anything about.
Old Nov 7, 2011 | 04:20 AM
Salvatorie's Avatar
At what point would I need to sleeve the block?
Old Nov 7, 2011 | 07:24 AM
blink182ska's Avatar
Block guards dont do much if not installed properly from a machine shop. Actually, they will destroy the engine if its even 1mm off balance in the block. Its gotta be precise, and it still aint really worth to have it in an engine build.
Old Nov 7, 2011 | 08:10 AM
Dioxine's Avatar
I dont know anyone who would install a block guard themselves. And thats your opinion. Lots of people run them with no problems its all in preference.
Old Nov 7, 2011 | 09:41 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
IMO I wouldn't waste my time with a block guard, not worth it.
Just do some research and look at all the setups out there.
350 on a stock sleeved B16 is easily attainable, esp if this is a track only car and will most likely be tuned on gas, e85, C16, etc).
Old Nov 7, 2011 | 04:10 PM
Schister66's Avatar
Man U FTW
Block guards, even if installed "properly" from a shop, are still worthless garbage and will most likely lead to an engine failure. They concentrate heat at the top of the cylinder. True, they reduce the cylinder's ability to move inside the cooling jacket casting, but they often obstruct coolant flow. Excess heat in the cylinder means hotter combustion cycles which can in turn cause detonation/pre-ignition = BOOOOM! Get my drift?
This is why you post turbo-related questions in the Forced Induction forum...its a little thing called "mis-information"
Old Nov 7, 2011 | 04:14 PM
Schister66's Avatar
Man U FTW
Listen to him. At least someone around here gets it
OP: Move to Forced Induction and ask your question there. You will have much better results
thugsbryan
Mar 27, 2015 09:48 AM
KFBhonda
Sep 8, 2011 03:24 AM
jv88_dc2
Jan 21, 2011 12:19 PM
b16ahybrid
May 8, 2005 01:31 PM
