Headlight connector stuck
Old Oct 24, 2011 | 08:57 PM
vtec29k's Avatar
Default Headlight connector stuck
How to open? Even pressing the clip down and pulling down does nothing. Don't want to break it. I am trying to replace the low beam bulbs.
Old Oct 24, 2011 | 09:03 PM
redbull-1's Avatar
Default Re: Headlight connector stuck
While pushing on the clip, use a flat-tip screwdriver and gently push the connector off.
Old Oct 24, 2011 | 09:11 PM
nus_dogg's Avatar
^ x2.
They get stubborns at times.
Old Oct 24, 2011 | 09:58 PM
NOFX's Avatar
H-T White Ops
x3.
I used to work in auto parts and cringed whenever I had to change '90-'97 Accord headlights. Almost all of them are difficult to remove.
Old Oct 24, 2011 | 10:40 PM
vtec29k's Avatar
Thanks, will give it a try again tomorrow.
Old Oct 26, 2011 | 07:50 PM
vtec29k's Avatar
Tried for a good 45 mins and looks like both are well stuck! Dammit. Also, must have blown the fuse for the passenger side as that headlight does not work. Got dark, so I will have to check tomorrow. Assuming that the fuse will be in the fuse box under the hood.
Old Oct 26, 2011 | 08:00 PM
Flagmichael's Avatar
Those things are devils. I have used silicone spray on them before prying (I have never removed one without prying) and that seems to help. I also wiggle them as much as I can before prying. Don't know if it helps or not.
Old Oct 26, 2011 | 08:12 PM
redbull-1's Avatar
While you press the tab in, use the flat-tip screwdriver and gently push down on each side of the plug (at the edges), do one side then the other. You might also try wiggling the plug a little from side-to-side. I always been able to remove any tough connector that way.
Old Oct 27, 2011 | 01:32 AM
NOFX's Avatar
H-T White Ops
They always feel like they're full of sand when I get them to disconnect. They just have this rough, dry feeling as you pull them apart.
I'd recommend cleaning them up and lubricating them before you get it back together.
Greatly prefer my '98 Civic's H4/9003 setup to this mess.
Old Jan 20, 2012 | 07:42 AM
schrecklich's Avatar
Thank you, redbull-1!!! I was pretty embarrassed that I could not even change a light bulb. I thought I must be missing something about how the connector worked. I was surprised how much of a difference the screwdriver made (using just my hand, I could not get the connector to budge at all).
Father
Sep 23, 2011 05:54 PM
lkelly
Oct 17, 2008 04:29 PM
meric
Honda Civic (2001 - 2005)
11
Dec 26, 2007 01:04 PM
JDMtype Eg6
Aug 4, 2005 07:36 PM
asubennett
Aug 27, 2004 10:13 AM
