HEadlight problem
Old Aug 26, 2004 | 05:44 PM
asubennett's Avatar
Default HEadlight problem
My left headlight went out. I replaced the bulb. And it is still out.
Could it be a fuse? Something else?
Suggestions?
Old Aug 26, 2004 | 06:12 PM
DB8_TEG's Avatar
Default Re: HEadlight problem (asubennett)
I don't think it would be the fuse cause I am sure both headlights work off of a single fuse if I remember correctly.
Check the wiring in the harness to see if anything is disconnected. Make sure the new bulb isn't blown either, just a thought, maybe take the bulb that you know works and put it in to make sure.
Old Aug 26, 2004 | 06:17 PM
asubennett's Avatar
Default Re: HEadlight problem (DB8_TEG)
Cool thanks for the thoughts. I actually did put the bulb I know works into it and it won't light either.
Old Aug 26, 2004 | 07:01 PM
RSVTECDC4's Avatar
the headlights arent run off one fuse. they have 2 seperate fuses. check the fuses under ur dash. if you look carefully, youll find the right side headlight fuse and the left side headlight fuse. check them both.
Old Aug 27, 2004 | 10:13 AM
asubennett's Avatar
Default Re: HEadlight problem (RSVTECDC4)
It was the fuse. Awesome, thanks guys.
-Racer X-
Jun 30, 2013 04:56 PM
efcivic317
Mar 16, 2010 02:27 AM
obsidianG35
Sep 12, 2003 01:50 PM
Charlie Moua
17
Apr 11, 2003 04:26 AM
TypeR 508
Apr 22, 2002 09:44 AM
