b18a1 trans-what goes to this?
It's the vent/breather for the transmission so it doesn't build pressure, blow seals, and the likes. You should ALWAYS fill the transmission from the designated fill plug... If for some insane reason you can't fill it proper, the next best spot is the VSS (by removing it obviously). If you look down the vent tube with a flashlight you will see what I mean. It takes forever to fill from that spot and you can't verify correct amount of fluid. Sure you can meter what is going in, but you can't account for what might already; unless of course you just reassembled the transmission...
ChrisJavier
Sep 8, 2021 08:31 PM
EG_Civic_Si
Feb 4, 2006 12:42 PM
thanks
