Quick ! Changing trans. fluid !
B16A2, Cable transmission. Can't tell which is the drain plug or filler plug. The bolts that I THINK are the ones are 17MM.
Fill plug?
Drain? (Underneath car, notice axle, Passenger side)
PLEASE HELP !!!
Fill plug?
PLEASE HELP !!!
http://img485.imageshack.us/my...x.jpg
the red circle is the fill plug. but you will sit there for one hour filling thick fluid through that hole. the green circle is the rec. one. i dont see your vehicle speed sensor so i cirlced where it should be. there should be three wires that go into a plug. vss loosens by one ten mil bolt....then the whols shaft slides out. fill fluid through there. go buy a rubber hose with a funnel (they sell them at checker/autozone etcc....) fill i believe 2.1 quarts?
Re: (waaBAAH)
theres a 17 mm bolt on the front of the tranny that is the fill. the bolt you have the arrow going to actually connects the tranny to the motor, and your missing the bolt below that
Re: Quick ! Changing trans. fluid ! (EG_Civic_Si)
On my d-series tranny, the drain plug is on the passenger side and is a 3/8" driver bolt. I fill the tranny through the vss towards the back of the tranny. Only one bolt holding that in... very easy to do it that way.
niceprelude
10
02-08-2009 04:20 PM
Adam_F123
11-25-2005 11:05 AM
