98 Prelude Head Gasket
Old Oct 8, 2011 | 01:11 PM
Brandon92's Avatar
Default 98 Prelude Head Gasket
What Parts Do i need when changing the head gasket and do i abousatly have to replace the head bolts or can i reuse them
Old Oct 8, 2011 | 01:33 PM
mike541's Avatar
Default Re: 98 Prelude Head Gasket
Measure the bolts when you take them out. Make sure you use an OEM gasket because different head gaskets require different RA finishes. I don't think you need any new parts?
Old Oct 8, 2011 | 01:34 PM
Brandon92's Avatar
ok what head gaskets would i need like upper lower etc
Old Oct 9, 2011 | 01:32 PM
mike541's Avatar
Are you sure your capable of this task?
Have you read the manual on the procedure?
There is only one head gasket. lol. So you need only one.
Old Oct 10, 2011 | 08:07 PM
Brandon92's Avatar
so why is rock auto asking me if i want and upper and lower or just upper
Old Oct 10, 2011 | 08:28 PM
mike541's Avatar
12251-P5M-004
Google that part number and order it. lol.
I have no clue where your getting the upper and lower thing... I just looked on Rock Auto and i dont see anything about an upper and lower head gasket.
Old Oct 11, 2011 | 11:56 AM
psud3ity's Avatar
Upper and lower usually refer to the "head gasket set" Upper set includes intake manifold and exhaust manifold, valve cover, etc. Basically the headgasket and up.
Lower would be well... lower.
REPLACE THE HEAD BOLTS. Head bolts are stretch bolts. I wouldn't bother measuring them. They have to be torqued properly. The ARP head studs you can get are not stretch bolts, and may be reused. Really would be a nice upgrade if you've got the $100 or so they cost.
You need a torque wrench as well. Use a good one. Rent or borrow it if you have to.
Old Oct 11, 2011 | 04:49 PM
99preludeowner's Avatar
mind as well get it sleeved while you're there. the upper is valve cover gasket and the lower is headgasket.
Old Oct 11, 2011 | 08:15 PM
Hidenplanvew's Avatar
I wouldnt use a rock auto headgasket... I would only use oem there about the same price and you will get it alot sooner. I would replace your Cam seals (3 of them look them up) and the dizzy o ring, valve cover gasket, sparkplug seals,... All pretty cheap and you might as well do it while the timming belt is off so you dont have to do it again... Might aswell as do a timming belt and waterpump...
Ohhh I got all the valve cover grommets that were on sale for 1.50 lol I bought all 30 of them, Honda wants like 11 bucks each
Old Oct 11, 2011 | 08:51 PM
mike541's Avatar
I didn't think they were torque to yield... replacing them is a smart thing to do though.
Cho0se
Feb 24, 2020 02:59 PM
rags00prelude22
Sep 10, 2008 08:26 AM
rico892002
Jul 25, 2007 05:54 PM
djtony5
Nov 2, 2005 02:40 PM
arielb1
11
Nov 5, 2004 02:38 PM
