B18c1 turbo rebuild still smoking- looking for insight
I have a b18c1 in my eg hatch and a while back it started smoking alot of white smoke, smelled like oil, maybe had coolant in it. Smoked particularly under boost. It all happened after i hooked up my boost controller to the wrong port on the wastegate and hit 5 lbs over what i was tuned to for a second or 2. anyways, i just finished rebuilding the bottom end with cp pistons eagle rods and new bearings. it smokes much less now when i drive it, and the oil is very clean looking after i check it. before it would be black as **** after even a few miles of driving even b4 the smoking issue. It smokes mostly now under compression braking, like if I down shift, and the smoke is like gray, smells like oil. WHen i got back to my garage I looked in the spark plug holes and one was completly full of oil due to me reusing the old seals for the valve cover- thats likely why it seemed to be misfiring at idle but that is likely a seperate issue. I looked in the cylinders and they have black residue on all 4 and seem slightly oily. I thus am in the process of replacing the valve stem seals and valve cover seals. Im also gonna try installing a oil catch can. ALso, I have arp studs and i retourqed those, and a new OEM headgasket I installed for the rebuild. I did not do any head work when i did the rebuild. Also, the turbo is freshly rebuilt by alamo turbochargers. Sorry for the long post, but im kindof lost at this point. Thanks for any input.
jdmcreations777
May 30, 2007 11:41 AM
