Built 01 Integra GSR Fuel Mileage
I have a 01 Integra GSR LS-T/VTEC, Eagle H Beam rods, CP pistons, Type R cams, stock GSR valves and springs, 5° valve job, stock intake manifold, stock fuel rail, stock distributor, NGK-R wire set, low heat plugs, HondataS300 with Demon board, Walbro fuel pump, 1100cc injectors, vented valve cover.....i believe thats it. As far as added weight theres a 8 point roll cage in the car plus myself im 145lbs. The motor is broken in with 400 miles and 12 quarter mile passes. It dynoed at 513hp 369 torgue running race gas at 25lbs boost. Im currently running 93 and it dynoed at 432hp cant remember the torque but that was at 16lbs boost. So with all that ive listed can anybody possibly tell me what my fuel mileage might be because its not a daily driver its my drag car so I havent tested the fuel consumption on a long distance drive.
I was wondering because I plan on taking it on a road trip to florida. Im from Virginia. Its a dumb question but I thought maybe somebody has a similar setup that knows there fuel mileage.
It wont be terrible. Turbos are actually much more efficient ways of running a petrol motor than just without a turbo. If you are easy on your foot you can easily get above 300k a tank.
Pullig
Feb 17, 2015 06:16 AM
therealPROJEKTEG
Oct 25, 2005 02:19 AM
