injector/rail/pump on e85?
Old Aug 12, 2009 | 03:59 PM
cousin_ed's Avatar
Default injector/rail/pump on e85?
like the title, what fuel rail/injectors/pump are you guys running on e85?
i have heard of certain fuel rails deteriorating from the use of E85.
also, would an aluminum fuel cell also react with e85?
Old Aug 12, 2009 | 04:03 PM
jdm602's Avatar
Default Re: injector/rail/pump on e85?
stock works perfect...except injectors, youll need some big ones. and no, an aluminum cell wont "react" with e85. but the stock tank works perfect too.
Old Aug 12, 2009 | 04:34 PM
96 GSR-T's Avatar
I would think raw un-annodized aluminum would oxidize.
Many have used the stock rail, reglator and tank with much success burning corn.
I know AEM's Rail and Reg did not show any signs of deterioration after leaving the stuff in the system for months at a time w/o running the car.
Old Aug 12, 2009 | 05:02 PM
cousin_ed's Avatar
i wanted to build my own fuel cell but i do not have the means to annodize. anyone else have any input about this???
Old Aug 12, 2009 | 05:06 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Stock Fuel Rail, Stock Injectors, Stock Gas Tank, Stock Fuel Lines, Stock Fuel Filter, Stock Fuel Pressure Regulator, NGK 5's, and a Walbro 255 Fuel Pump.
I have been running it like this for over 3 years with out problems. (Yes, I have pulled off the fuel rail and FPR yearly to see if there was corrosion present.)
Car = 1991 CRX Si with a OBD-0 B16A Swap
Old Aug 12, 2009 | 05:19 PM
cousin_ed's Avatar
who has ran aftermarket stuff that held up with E85?
my setup will make clkose to 500 when i switch to corn...not retaining stock anything...
Old Aug 12, 2009 | 05:32 PM
jdm602's Avatar
a buddys eg hatch pushing 750+ and hes still using stock rail and fpr.
but im sure aftermarket rail works fine too. im using an aem fpr and its holding up great.
Old Aug 12, 2009 | 07:06 PM
DO IT ON ALL FOURS
You can do 500 HP with stock everything besides fuel pump and E85... it has been done many times before...
Old Aug 13, 2009 | 08:11 AM
cousin_ed's Avatar
stock rail can flow that much on corn???
what size injectors do you guys reccomend for a 475hp lsv on corn? 1000cc?
Old Aug 13, 2009 | 08:53 AM
SilverEk3dr's Avatar
You will need 1000 at very least, and even they will start to fizzle at 450. Get the ID1000s, a weldon 0-120psi regulator, a walbro in-tank and 044 bosch in-line. Then go play. BTW thats my setup and Im going back to try and max the fuel system out this time. So maybe 550-580ish? Not sure exactly.
Old Aug 13, 2009 | 10:17 AM
cousin_ed's Avatar
sounds great! i have the walbro and was already planning on the ID1000s and the 044. this is a street/strip car that rarely gets driven. was thinking about an underhood fuel cell. what do you guys think about underhood cells? seen lots of them on drag cars.
Old Aug 13, 2009 | 12:59 PM
96 GSR-T's Avatar
completely unnecessary, not to mention where are you going to fit a cell big enough to even allow you to drive anywhere without running out of gas? Your going to use roughly 30% more fuel in your tune and your MPG will show it accordingly.
We have 8 sec street Honda's using a gas tank in the back of the car.........
Old Aug 13, 2009 | 04:28 PM
cousin_ed's Avatar
i will probaly use an aluminum fuel cell mounted where the spare goes instead. i already dropped the tank.
Old Aug 13, 2009 | 05:47 PM
civic-r11's Avatar
just get the bosch fuel pump and the fpr. and the 1000cc injectors. but they will be running out or steam around 450 to 500.. but it is all good.. there is not way.. you can get that much power out of stock injectors.. please don't listen to people on hear that say things that are not true..
prodragEG
Jul 31, 2008 03:53 AM
01_ITR
Jul 21, 2008 03:19 PM
Topdawgg
Nov 24, 2006 05:15 PM
275Performance
Jan 19, 2004 05:36 AM
