Looking for a parts list B18 LS into 97 CIVIC EK help
Old Oct 1, 2011 | 03:01 PM
JDM_NANO's Avatar
Icon2 Looking for a parts list B18 LS into 97 CIVIC EK help
So im purchasing a full swap from jdmenginezone i want to know is there any thing else that i need after i get the swap from the enginezone
i know i need shiftlinkage for b series and bseries motor and trans mounts any thing else thanks
Old Oct 1, 2011 | 03:44 PM
96electronH's Avatar
Default Re: Looking for a parts list B18 LS into 97 CIVIC EK help
si rear t bracket and bracket by timing belt. b series axles. its plug and play 90% if you have a ex
Old Oct 1, 2011 | 03:53 PM
apexi_rsx's Avatar
and B series em1 or integra front spindles
Old Oct 1, 2011 | 04:41 PM
98cdmej6's Avatar
literally just did this swap. today is my first day running around with it!
some of the problems i ran into was radiator hoses they are a little different you'll need some ones from an integra and power steering(if your keeping it) you'll need a b-series p/s pump
Old Oct 1, 2011 | 04:45 PM
ReDHaTcHyGuy's Avatar
^ no you dont
only thing u need is the rear triangle bracket and the 2 post block mount from a Si mount wise, and of course shift linkage and axles...
it would help if you listed exactly what car it was going into
Old Oct 1, 2011 | 05:40 PM
apexi_rsx's Avatar
.. i know when i swapped a b18 in a ef we swapped the whole front spindle to the upper a arm all in one piece from a donor car. maybe not a necessity but could benefit with larger rotors and brakes if its not a ex.
Old Oct 1, 2011 | 06:17 PM
92EGLSVTECEATER's Avatar
I swapped my ls b18b into my 92 hatch i know it is a little different.My point is i just got the shift linkage from Hasport even know i had my oem for about$150.I was too lazy to refinished the one from my integra.About the radiator hoses my were different as well having a larger diameter ports on the b18.For a could of weeks until i installed my 3 row koyo i rigged it with plastic pipe reducers from the hardware store.Hope this helps a little.Peace
Old Oct 1, 2011 | 06:32 PM
98civdx's Avatar
Master Detailer
For these car's they're actually the same, for exception of the brakes.
Old Oct 1, 2011 | 07:20 PM
hon2984's Avatar
ECU! B series throttle cable!
If the swap is OBD1 you will need to do a 3 wire IACV to 2 wire conversion
Old Oct 2, 2011 | 05:06 AM
nur53_401k's Avatar
no you can get the power steering bracket of a crv google part number or a 99-00 si with b16
Old Nov 8, 2011 | 05:12 PM
jofat91's Avatar
can i use a motor mount bracket from a 92 integra??? i cant find info anywhere
Old Nov 8, 2011 | 05:56 PM
98civdx's Avatar
Master Detailer
NO
prego698
Mid-Atlantic (Sales)
Apr 29, 2011 11:13 AM
maal15
Dec 31, 2010 07:56 AM
j.RUNek9
Nov 9, 2007 02:44 AM
WhiteEkCivic
Sep 16, 2007 06:07 PM
Adrian G. Aka JDMonkey
Sep 5, 2007 11:00 PM
