Ls Swap Questions???
I know that everyone on here is gonna have something bad to say about me asking this question but I've looked and I cant find the answer I am looking for. I am doing an LS swap in my EK and I know that I need the linkage from the integra but im not sure what mounts I need to use.... Do I use the ones from the integra or do I need to get special mounts just for the swap?? And should I change the fuel pump to compensate for the LS?? I would think the d16 pump wouldnt be good enough. If you guys could help me with this I would really appreciate it.
ugh.
yeah, its a b series swap, use the same mounts as any b series swap, the only difference would be if you're go auto-manual.
you couldn't possibly have searched.
Re: Ls Swap Questions??? (WhiteEkCivic)
The stock fuel pump is fine for a stock/lightly modded LS..
You can use the stock drivers side post mount, but you need the bracket and the piece that connects to the engine..
you need a rear trans bracket from a civic si and tranny mount bracket for the trans youre using..
basically #5, #6, #7.. (i think #5 is the piece)
You dont need the whole number #4.. just the piece that connects the post mount to the engine..
You also supposidly need this mount.. i dunno.. i got a new one and it looked exactly the same as the LS bracket.
#8 is the bracket.. if you order it, you might wanna order new studs.. it doesnt come with them.
The Integ ones will work. If your ballin' Get has Hasport EK b-series mounts. And the D16 fuelpump should work fine. Unless you want to upgrade to a Walbro 255. Up to you.
theslugbug
01-01-2007 06:42 PM
