honestly weird problem will not start!! check this out
Old Sep 26, 2011 | 06:31 AM
bnmm's Avatar
Default honestly weird problem will not start!! check this out
95 ex. with a 95 cx engine and harness did the swap myself and it started righhtttt up went to bed and woke up the next day, it wouldnt start. a relay clicks in the fuse box under the hood, like when u dont hold the clutch in, i jumped the clutch safety, checked fused grounds, every thing i could think of. only starts if i jump the starter to battery, battery is good. and the ignition switch is good
Old Sep 26, 2011 | 06:35 AM
Moonraker09's Avatar
Default Re: honestly weird problem will not start!! check this out
Can you explain how did you test the ignition switch?
Old Sep 26, 2011 | 06:41 AM
98greensi's Avatar
check engine to chassis grounds and make sure the ecu plugs are pushed in all the way
Old Sep 26, 2011 | 06:45 AM
Former User's Avatar
Clean and tighten the G3 transmission ground and both starter wires.
Old Sep 26, 2011 | 06:58 AM
bnmm's Avatar
i did what the hanes manual said to check it, turned the key and checked continuety between certain wires at a certain point, u think it could be a ground workin one hour and not the next? and i checked all the ecu plugs
Old Sep 26, 2011 | 06:59 AM
bnmm's Avatar
starter has power at both points too everything is in contact
FCUKINSLAPPY's Avatar
check the thermastat housing ground.....
Old Sep 26, 2011 | 07:15 AM
bnmm's Avatar
i just did took it off and cleaned it, but the fuel pump works so i didnt think it was that everything works all electrical is fine but the passenger door wont work now
Old Sep 26, 2011 | 07:24 AM
bnmm's Avatar
any ideas? ideas how i can text something maybe
lilsol89
Jul 15, 2008 07:40 AM
Pockets
Dec 19, 2007 05:24 PM
strils
Jan 11, 2007 08:06 PM
ninety4lscoupe
Mar 21, 2006 02:47 PM
morphics
34
Nov 4, 2005 05:41 AM
