honestly weird problem will not start!! check this out
95 ex. with a 95 cx engine and harness did the swap myself and it started righhtttt up went to bed and woke up the next day, it wouldnt start. a relay clicks in the fuse box under the hood, like when u dont hold the clutch in, i jumped the clutch safety, checked fused grounds, every thing i could think of. only starts if i jump the starter to battery, battery is good. and the ignition switch is good
Re: honestly weird problem will not start!! check this out
i did what the hanes manual said to check it, turned the key and checked continuety between certain wires at a certain point, u think it could be a ground workin one hour and not the next? and i checked all the ecu plugs
i just did took it off and cleaned it, but the fuel pump works so i didnt think it was that everything works all electrical is fine but the passenger door wont work now
