JDM b16 Spark plugs
Old Sep 25, 2011 | 09:22 AM
JDMCIVIC919's Avatar
Default JDM b16 Spark plugs
Im going to do a tune up on my jdm b16 gen 2 motor soon. I was wondering what the best spark plugs would be best for me? The motor has about 100k on it. Has Intake, rmf header, greddy sp2 exhaust, ITR cams, and tuned on 93 octane. Im also going to go with OEM wires or should i go with NGK?
Old Sep 25, 2011 | 10:13 AM
tayyab74's Avatar
Default Re: JDM b16 Spark plugs
yes u can go with ngk.
Old Sep 25, 2011 | 10:41 AM
Ive read up for wires that OEM is best and than i also here the NGK's are better. For my setup what would be the best?
Old Sep 26, 2011 | 07:21 AM
Red_Army's Avatar
sumito(oem wires) ngk copper plugs.
Old Sep 27, 2011 | 05:04 AM
ReDHaTcHyGuy's Avatar
dont get copper plugs, get NGK v power plugs, they're the base NGK plug and are actually the best u can use on a honda.. all that platinum irridum BS doesnt make a big difference on a honda, only in your wallet... most big turbo guys run them just in a different heat ranges... you should just get plugs and wires for a 99-00 Si, V-powers are like 2 bucks a piece ...
Old Sep 27, 2011 | 05:13 AM
dpetro1's Avatar
Actually V-power are copper core plugs and all that I use as well. Copper is a better conductor of electricity but the plugs don't last as long. So that's the trade off versus using iridium. Ngk or Denso iridiums are oem in most Honda's these days.
Old Sep 27, 2011 | 05:21 AM
well i didnt wanna confuse him and have him going to napa asking for copper plugs and them selling them some BS..lol v power plugs will last just fine.. most plugs now adays are designed to last 100k before changing them..
Old Sep 27, 2011 | 06:03 AM
dpetro1's Avatar
Vpowers will not last 100k. I change them every other oil change or so. Mine is a turbo application though.
Old Sep 27, 2011 | 06:22 AM
Libertariat's Avatar
Ek Forever y0!
OEM wires are hands down the best wires for the money. And there is zilch wrong with OEM plugs. I've seen several dyno tests over the years.
IF there is a discernible difference it's not enough to spend more than 2 minutes deciding which spark plug to get.
Properly gapping them will do more for your engine than the type/brand of plug. OEM plugs are cheap, and work great.
Old Sep 27, 2011 | 10:47 AM
Grujo's Avatar
oem wires and NGK V power all the way on my turbo gsr motor!!
Old Sep 28, 2011 | 03:08 PM
i meant plugs in newer cars like my old 07 Si ,and yea being boosted you would be changing plugs that often lol
Old Sep 29, 2011 | 01:00 PM
Ok thanks everyone. What should i gap the spark plugs at? or should i just leave them. Im going to get the vpowers. These right here
http://www.autozone.com/autozone/acc...er=444815_0_0_
Old Sep 29, 2011 | 01:23 PM
whatever stock is, they are usually pre gap'd right but i always double check them..
Old Sep 29, 2011 | 04:54 PM
dpetro1's Avatar
No, you do no want those! You want stock# 2756 the bkr6e-11. They will be pre-gapped.
The ones you linked are a heat range 8 non-resistor racing plug. It would fit the engine but would foul quickly. These are used on 500+ whp turbo motors.
Old Sep 29, 2011 | 06:19 PM
egsleepercivic's Avatar
I believe the 11 in the part number corresponds to the gap 1.1mm, I would check the gap before install even if they are pre gapped, I have had sets where the gap was perfect out of the box and some that needed adjusting and BKR6E-11 is what you want as stated above
Old Sep 30, 2011 | 06:37 AM
dpetro1's Avatar
Very true. Always double check the gap.
Old Sep 30, 2011 | 03:12 PM
these, you want a stock replacement plug not a racing plug
http://www.autozone.com/autozone/par...Z9n80xZ1z0zbuv
Old Sep 30, 2011 | 03:24 PM
that_boy_sammy's Avatar
JDM or not those laser spark plugs that they sell at usually any auto parts stores are the ****. Its a laser beam instead of actual spark. They work really well.
Old Mar 20, 2015 | 03:56 PM
gabrielsousa's Avatar
has anyone tried PFR7G-11S ?
Old Mar 20, 2015 | 04:01 PM
NotARaCist's Avatar
I never narc'd on nobody!
You just bumped a 4 year old thread, to ask if anyone has used a plug that, yes, thousands of people have used...
What the actual ****?
Old Mar 20, 2015 | 04:04 PM
its better than BKR7E-N-11 ? or there's no difference on a b16a ?
Old Mar 20, 2015 | 04:15 PM
NotARaCist's Avatar
Holy fuckshit. Not only did you miss what I was saying, you obviously haven't even bothered to read the thread. Unfuck yourself. Read the ******* thread you posted in. V Power is better than Platinum, but Platinum will last longer.
Old Mar 20, 2015 | 04:22 PM
sorry for not explain better, since ppl are talking about stock, and stock for b16a is BKR7E-N-11,
my question was.. if PFR7G-11S would be a good choice for b16a
Old Mar 20, 2015 | 04:34 PM
NotARaCist's Avatar
Your question has been answered. I have answered it. Two other people have answered it in this thread. The FAQs have answered it. It's been answered hundreds of times already. Do you still not understand?
Old Mar 20, 2015 | 05:44 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Size:  949 BytesI'm closing this thread before it gets out of hand (sort of has already, thanks NAR Name:  naughty.gif
Lets help you answer your own question. Is your plug in question the same heat range as the stock plug? Is your plug in question copper or some other material.
If you said yes to the heat range and yes to copper and it is the same physical dimensions as the stock plug... Then yes it will be fine on your vehicle assuming a rather stock setup. If you said no or some other answer to either of those two questions, it has been stated in this thread multiple times that it's not as good for your motor.
digitalvice
17
Mar 25, 2013 03:14 PM
pacey
Oct 20, 2007 01:21 PM
veritasaequatis
14
Feb 6, 2007 03:08 PM
litterbox
May 10, 2004 07:29 AM
jdmjeff
12
Nov 20, 2003 01:26 AM
