what are the best spark plugs???
I'm planning on putting new spark plugs in my eg this weekend and I need to know which ones to buy. I'm runnin' NGK in the coupe now. Also I was wondering if I were to buy aftermarket spark plug wires would it be worth it and if so which ones. Thanks
Re: what are the best spark plugs??? (jdmjeff)
I run NGK plugs and Bosch wires on my gf's 98 ex. If you have money to burn, get the Denso ones, there is a version that is like $13 per plug.
Re: (dynastix9)
im using the denso iridium ones. they work great but i really didnt notice any difference in performance. i just wanted to try them out and see. next time i go to the dyno im going to bring a set of ngk and see if there is a difference at all. be very carfull with your choice though. i would say ngk or denso
um..
spark plugs won't give you much of a difference.
the wires would help you more though..
the only benefit i see, from getting some platinum-tipped "high performance" plugs is that they last alot longer than the stock plugs.
and yes, i do know that the high-performance drag cars/cars with alot of power NEED these plugs.
BUt anyways, the wires should give you better response and do more than the plug itself.
meagainsttheworld
03-19-2007 07:11 AM
