normal deposits or detonation?
heat range 8
Spots are tannish and perhaps a little grayish in color. Plugs have been in the car for 5000 miles approx. Car runs good, 8psi, 8.5:1 compression. Let me know what you think.
No, these plugs were pulled during a cam swap. They weren't pulled after a pull. I was just curious if they were evidence that the car was detonating. Engine is 8.5:1 with a GT3076r. Timing is around 16* at peak torque, climbing to 21* at 7500rpm.
Don't want the engine to get hurt, but I thought the tune was ultra safe for the pump gas, considering this was 8psi map.
I am on 91 pump gas. And I know that the plugs should have been pulled after a pull to check for detonation, but I was curious why the deposits were there. Not sure if it was signs of past detonation or not, but I figured 8.5:1 compression should be rather safe. Engine is runnin 13psi now. Going to dyno and putting new plugs in.
porter
Oct 18, 2006 11:25 AM
ludewithanh22
Oct 9, 2004 11:56 AM
