normal deposits or detonation?
Old Sep 23, 2011 | 07:08 PM
Coheed's Avatar
Default normal deposits or detonation?
heat range 8
Spots are tannish and perhaps a little grayish in color. Plugs have been in the car for 5000 miles approx. Car runs good, 8psi, 8.5:1 compression. Let me know what you think.
Old Sep 24, 2011 | 08:33 AM
welfarepc's Avatar
Default Re: normal deposits or detonation?
did u pull those after shutting down in the middle of a full power pull? if yes, i would say try taking out some timing and checking the plugs again.
Old Sep 24, 2011 | 09:29 AM
Gunmetal_B20_Hatch's Avatar
last pic looks like a bit of detonation to me...
Old Sep 24, 2011 | 07:01 PM
Coheed's Avatar
No, these plugs were pulled during a cam swap. They weren't pulled after a pull. I was just curious if they were evidence that the car was detonating. Engine is 8.5:1 with a GT3076r. Timing is around 16* at peak torque, climbing to 21* at 7500rpm.
Don't want the engine to get hurt, but I thought the tune was ultra safe for the pump gas, considering this was 8psi map.
Old Sep 25, 2011 | 05:01 AM
blackeg's Avatar
even at peak torque, 16 degrees seems low for 8 psi and 8.5:1 compression. 21 degrees up top sounds ballpark. what octane pump gas?
Old Sep 25, 2011 | 08:31 AM
SovXietday's Avatar
Not much you can tell from an old set of plugs that you pull during a cam swap.
Old Sep 25, 2011 | 09:06 AM
h2.4's Avatar
put new plugs in and do a wot pull, or two, and shut down pull plugs and take more pics. Hard to read crusty *** plugs from awhile ago.
Old Sep 25, 2011 | 10:09 AM
Turbo-LS's Avatar
They do show signs of detonation but it's bet to do a power pull with a fresh set and shut it down and pull plugs then Take pics
Old Sep 28, 2011 | 08:33 AM
Coheed's Avatar
I am on 91 pump gas. And I know that the plugs should have been pulled after a pull to check for detonation, but I was curious why the deposits were there. Not sure if it was signs of past detonation or not, but I figured 8.5:1 compression should be rather safe. Engine is runnin 13psi now. Going to dyno and putting new plugs in.
porter
Oct 18, 2006 11:25 AM
turbo_ef9
Aug 30, 2005 07:20 PM
ludewithanh22
Oct 9, 2004 11:56 AM
Jaydeep
Sep 14, 2004 09:17 AM
Pepsi90919
Oct 17, 2002 10:12 AM
