biggest b18b bore possible! help
Old Sep 19, 2011 | 12:49 PM
ej1bseries's Avatar
Default biggest b18b bore possible! help
Whats up Honda-tech, sorry if im askn a question that has been askd b4, im going to bore my ls block, and was woundering if any 1 knew wat is the biggest bore i can go with high compression pistons with a non sleeved block!! Any info well help thnx
Old Sep 19, 2011 | 01:33 PM
88Hatchy's Avatar
Default Re: biggest b18b bore possible! help
82mm
Old Sep 19, 2011 | 01:48 PM
ej1bseries's Avatar
Thnx now would u think i woulda b good wit stock ls rods or that rilly wont matter, and do yu kno whats the highest compression i can go nd stay on pump gas, im still debating if i wana go race gas or not!
Old Sep 19, 2011 | 01:58 PM
Builda'Teg_92's Avatar
Ouch that hurt my eyes...
You give no info...what r u "trying" to do?
Old Sep 19, 2011 | 02:05 PM
ej1bseries's Avatar
I have a ls block which was bord to 81.25 with ctr pistons which i was on pump gas, i fried a piston and now my block is in the shop and i want go with a big bore(non sleeved), with high compression pistons with mostly everythng stock just use some arp rod bolts nd a block guard, but i want to make sure im going to b on a safe side, so i want to know whats the biggest bore i can go and be safe and also after what compression racio would i have to go with race gas.
Old Sep 19, 2011 | 02:11 PM
EsotericImage's Avatar
Retired Moderator
block guard huh
Old Sep 19, 2011 | 02:17 PM
ej1bseries's Avatar
Originally Posted by EsotericImage
block guard huh
Ya with a golden eagle block guard
Old Sep 19, 2011 | 02:27 PM
C_Rock77's Avatar
The kind/amount of help you need isn't going to be found in any single thread....sorry
The fact that this wasn't a clue just reinforces my view.
I have something for you to work on for your nest post: Learn to make an intelligible that doesn't require a decoder ring or for a person to read 3+ times to try to understand your line of thought.
Thank you
Old Sep 19, 2011 | 02:34 PM
ej1bseries's Avatar
Like i said the 1st time im new to the pg so if i wantd ur wise answer i would of acted like i knew what the hell i was talking bout, thats why i asked the question twice if i didnt make it clear enuff my bad
Old Sep 19, 2011 | 02:43 PM
93egSLEEPER's Avatar
English Language-1
ej1bseries-0
Old Sep 19, 2011 | 03:04 PM
Mr. EG's Avatar
Why are you using CTR pistons
Old Sep 19, 2011 | 03:19 PM
Golden Eagle's Avatar
Hey ej1bseries, the max you can go on stock sleeves for your LS block is 81.75mm. Going 82mm is really pushing the limit on the stock sleeves and boring out stock sleeves in general is a very risky maneuver to do.
- Kenny
Old Sep 19, 2011 | 03:20 PM
ej1bseries's Avatar
Mr.eg, i was using ctr pistons because i only went to 81.25mm and i wanted to go with a high compression set up. So i decided to go with those, this time around im not sure if thats what im going to use since ctr pistons only come 81.5
Old Sep 19, 2011 | 03:24 PM
Also you're welcomed to PM me if you have anymore questions.
Old Sep 19, 2011 | 03:29 PM
Question:
why are you so compelled to go with a BIG BIG bore & HIGH HIGH compression on i assume a daily driven car. As said above, everything you need to learn will not be found in here....
Just answer this......how much hp are you looking to get.
Old Sep 19, 2011 | 03:52 PM
ej1bseries's Avatar
Thank you Golden Eagle, and builda'teg its not going to be a daily drivin car, and my thought of going with a big bore and high compression it to get some good power with a all motor set up. And im looking for around 200-230hp.
Old Sep 19, 2011 | 04:03 PM
All motor aint cheap....and right now your knocking at the door of expensive parts with 230hp.
Old Sep 19, 2011 | 04:18 PM
ej1bseries's Avatar
i agree its not, i have a b16 which is completely done, but now my worrys are on the block. If i cant go to big on the bore i will just stay at 81.5mm. By any chance do you know after what compression ratio should i be on race gas?
Old Sep 19, 2011 | 04:30 PM
ej1bseries's Avatar
b16 head** sorry
1/4mi4banger
Engine Machining & Assembly
Oct 31, 2015 02:35 PM
B18c1turboedEK
Nov 26, 2003 10:48 AM
Chris Benoit
Aug 10, 2003 09:22 PM
TriK
Jun 6, 2003 09:26 PM
teamrushhatch
Jun 1, 2003 03:08 AM
