Water/Alcohol injection
Old Oct 4, 2002 | 08:13 AM
jdmcx's Avatar
Default Water/Alcohol injection
what are the facts about acohol injection?
i was told that i prevents detonation the reason that i am asking is that i am running some high compression pistons in my lsvtec and am using 100 octane right now but is is expensive ($4.00 a gallon) so i body told me about alcohol injection thing is his car is turbo and mine isn't can i still run alcohol injedtion his one kicks in under boost how will i be able to turn mine on?
any and all fact about alcohol injection will be helpfull thanks for you time and assistance
jason
oh what are som good kits avalable and where to get them and how much
Old Oct 4, 2002 | 08:52 AM
jdmcx's Avatar
Default Re: Water/Alcohol injection (jdmcx)
ttt
Old Oct 4, 2002 | 10:32 AM
The_Oz's Avatar
There are kits available for NA cars. OR you could make a ghetto kit. I wouldn't exactly call it ghetto, because if you do it right, you can have a good kit for a fraction of the cost.
In any case, the major advantage that water-injection offers is to prevent detonation...a turbo owner's worst nightmare. So, in essence, with water injection, you can run with lower octane gas, advance ignition timing, OR increase compression...I personally wouldn't recommend doing all at the same time. Also, another advantage that I keep reading about is that steam (the byproduct of water injection) acts as a cleaner removing carbon deposits and such.
If done right, water-injection can be very beneficial - especially those with turbo setups. I'm not sure if this system is compatible with N20 applications. And yes, an NA engine will require a different setup than a turbo engine.
I'll see if I can come up with some links for you.
Regards,
Oz
Old Oct 5, 2002 | 04:20 PM
jdmcx's Avatar
Default Re: Water/Alcohol injection (The_Oz)
Thanks for the help i appreciate it and if you can find some links that would be cool
Old Oct 5, 2002 | 10:22 PM
The_Oz's Avatar
http://aquatune.com/index.asp
Something to start you off. I personally would research a DIY kit (actually, that's what I'm doing right now ).
Regards,
Oz
iNERtIA
May 26, 2006 10:09 PM
turboZChatch
Oct 23, 2004 01:08 AM
morepoop4u
Sep 27, 2003 05:41 AM
boosted hybrid
Dec 3, 2002 10:35 AM
AlphaKennyWun
Jul 3, 2002 09:58 PM
