Water injection
Old Oct 22, 2004 | 01:25 PM
turboZChatch's Avatar
Default Water injection
Who here is running a water injection kit I have recently purchased one from spearco and would like to know some feedback on these things like dyno results...performance...good..bad all feedback is helpfull thanks
Old Oct 22, 2004 | 08:13 PM
Default Re: Water injection (turboZChatch)
nobody here has any kind of feedback with the water injectoin kit????????
Old Oct 22, 2004 | 08:38 PM
Boostage's Avatar
alcohol injection is better... no MUCH better
Old Oct 22, 2004 | 09:29 PM
Default Re: Water injection (Boostage)
well it is the alcohol/h20 injection kit from spearco anyone running this setup
Old Oct 23, 2004 | 12:51 AM
bee18's Avatar
water/alcohol is a great set up for high boost cars, i will most likely beusing it, great for preventing detonation.. you can make your own diy kit... how much is spearco's by the way?
Old Oct 23, 2004 | 01:08 AM
The Meat's Avatar
I have a progressive contolled unit. Pump pressure is increased as boost level rises. This helps to eliminate the bogging effect of spraying a large amount of methanol at a low rpm/low boost level. Be sure to add either Marvels Mystery oil or Klotz lube to your mix.
speed1
Mar 9, 2010 06:22 AM
BluntMan
Dec 6, 2003 10:22 PM
morepoop4u
Sep 27, 2003 05:41 AM
blufke
Nov 19, 2002 07:32 PM
AlphaKennyWun
Jul 3, 2002 09:58 PM
