Sensors Question
Old Aug 22, 2011 | 05:58 PM
Zukka's Avatar
Default Sensors Question
Okay I have a gs-r turbo in my eg and been trying and trying to get it going its always one thing after another lol. But i had a friend come out and help he said the reason it wouldn't was because it was an obd2 harness, but what gets me is it did used to start and run. Then i got hondata and it still started but had a hard time at idle. Well to my question i converted the harness from obd2 to obd1 from a b16. Well i dont know which is my IAT( Idle Air Temp.) which is on my third runner, right? and my ECT( Engine Coolant Temp.) when i have my computer hooked up it says they are both at -100 degree which means its not the right plug so any thing would help. Thanks guys
Old Aug 22, 2011 | 06:21 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Sensors Question
What? Try that again.
Old Aug 22, 2011 | 07:54 PM
Former User's Avatar
Match your sensors to wire colors in the sensor connectors.
http://www.phearable.net/tech/wiring...schematics.gif
Old Aug 23, 2011 | 12:40 AM
boostedteg909's Avatar
on my obd1 harness in my integra the iat sensor connector is on the part of the harness wit the injector connectors. the ect is on the part of the harness along wit the distributor connectors. i believe the vtec pressure switch, charcoal canister purge solenoid, iacv, nd the connector that goes to the rack also has the same connectors so dnt get them confused. ect sensor has red/white, green/black. nd iat has red/yellow, green/black
Old Aug 23, 2011 | 01:23 AM
HondaPartsHero's Avatar
Technical Hero
Is your check engine light on?
Old Aug 23, 2011 | 07:49 PM
Zukka's Avatar
uhh ok sorry guess no one understood me i know where they are located my question is what color are the wires so i can get the right plug hooked up! lol..but yes my check engine light is on!
Old Aug 23, 2011 | 07:52 PM
Did you click the link I posted?
Post the number of pins and wire colors in disconnected or mismatched connectors. Pictures would help.
Old Aug 23, 2011 | 07:54 PM
Old Aug 24, 2011 | 11:00 AM
Zukka's Avatar
oh dang sorry boostedteg909 i must have just stopped reading before i saw that thanks let me go check thanks ill let you know if it fixes it
EJ7-4dr
Jul 2, 2012 05:52 PM
jaron_cc
May 21, 2009 10:43 AM
CivicB18C1
Jun 13, 2008 05:47 PM
fcfromhell420
Sep 22, 2007 05:06 PM
tremor86
Jan 15, 2004 05:54 PM
